How do I calculate the deflection of an L-shaped pipeline with added loads?
  • Thread starter Thread starter albertseng
    Deflection Shape
To calculate the deflection of an L-shaped pipeline under various loads, the weight of the pipe can be treated as a distributed load, while the flange can be considered a point load. The deflection will also be influenced by any additional downward loads, such as those from contents like water or coal tar pitch. An energy approach, specifically using Castigliano's theorem, is recommended for analyzing the deflection, especially at the elbow. It is crucial to account for both the weight of the pipe and any other loads when determining deflection. Understanding these factors will lead to a more accurate assessment of the pipeline's structural performance.
albertseng
Hello,
Uncle have one question.
How to calculate the deflection of the upper flange if the pipe configuration is like the attached picture. How to include the weight of the pipe, can I assume it as the distribution load? And what if there is another load acting downward at the middle of the upper side.
deflection due to weight? Or heat? what? Full of water? Full of coal tar pitch? Half full?
The most difficult part will be the analysis of the elbow.
Hi Travis_King,
Let say I have an empty pipe. So the deflection is just due to the weight of pipe and and the flange, right?.
Yep, the weight of the pipe can be considered a distributed load. The flange may be considered a point load.
An energy approach (Castigliano) may be your best bet here.
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
