Labelling graphs/images with text() function
  • Thread starter Thread starter nyxynyx
    Function Text
The discussion revolves around a user attempting to label circles in a 20x20 arrangement with numbers from 1 to 400 using a coding approach. The initial code provided does not function as intended because it attempts to label with numbers directly. A solution is suggested to convert the numbers to strings using the num2str function, which resolves the issue. The user confirms that this solution works effectively.
nyxynyx
Hi, I'm plotting some circles in a 20x20 arrangement using the rectangle tool and I have to label each of the circle a number from 1 to 400. However, the following code does not do what i once, since i think i can only label with strings and not running numbers...
Code:
for i=1:400
    text(x_pos(i),y_pos(i),i)
end
What else can i try? Thanks!
You could just convert the number to a string using the num2str function.
Look it up in the help.
thnx f95toli this works!
