Lactate, Exercise & Cramps: Questions Answered
  • Medical
  • Thread starter daniel_i_l
In summary, stretching may help with venous blood return, but it won't do anything to help with lactate buildup.
daniel_i_l
Is it important to drain your leg muscles of excess lactate after running in order to avoid cramps? Is that what stretching does? Can you get the lactate into you blood just by shaking them?
Thanks.
Biology news on Phys.org
I don't know about 'draining' anything from your legs by stretching. Lactate builds up primarily from anerobic respiration. This comes about as oxygen levels in muscle tissue get low.
People who are in very good shape still stretch, but their lactate buildup is less than someone who is in poor shape.
Stretching is more of a way to get stiff muscles and connective tissue loosened up so that it is not damaged as readily by extreme demands. A more exact discussion meant for runners:
http://www.runtheplanet.com/trainingracing/stretching/chap1-whathappens.asp
You don't really drain lactctic acid from your legs. I don't exactly remember how, but lactic acid can be run through the citric acid cycle once the muscles in your legs have enough oxygen to do so. (The reason that your cells produce lactic acid in the first place is because your cells need more oxygen than they're getting, so in order to make quick atp, they skip the whole aerobic respiration part and get atp through lactic acid fermentation)
I'm big into distance running, and I find that the best way to get that burning sensation out of your legs from the build up of lactic acid is to just slow down the pace and let things work themselves out. Cramps, however, are not caused by build up of lactic acid as much as a few other things. The major culprit there is either an imbalance of sodium and potassium (usually less sodium) or dehydration. To get rid of cramps, eat foods rich in potassium through the day and drink something like half water and half gatorade while you work out. You can even just put some salt in your water(just make sure you don't have too much to drink at once, because then you'll get those side cramps or side stiches.) However you do it, just make sure that your body is getting a good balance of water and sodium before, during, and after a workout.
Also, if your legs are sore the next day, its good to stretch them and go for a short, easy run. The running will usually work out problems as long as you don't do too much.
As has been pointed out, stretching won't do anything for lactate build-up, since that's intracellular. What it may help out with is simple venous blood return. In the lower limb, especially, muscle contractions aid in circulation by helping compress veins to move blood back up counter to gravity. But I'm not completely sure if that's a function of stretching post exercise, or only the stuff jim talked about above.
pheidippides said:
.I don't exactly remember how, but lactic acid can be run through the citric acid cycle once the muscles in your legs have enough oxygen to do so. (The reason that your cells produce lactic acid in the first place is because your cells need more oxygen than they're getting, so in order to make quick atp, they skip the whole aerobic respiration part and get atp through lactic acid fermentation)
I thought only pyruvate was run through the citric acid cycle...?
I think that the effect of stretching is limited. After a workout you should eat something and then do a light workout. That light workout will help you to recover faster. I've read that many athletes do this. I also used to do this when I exercised twice a day. I would exercise before lunch. Then, after lunch I would do a light workout which helped me to recover enought to do an intensive workout before dinner. Then after dinner I would do a light exercise again.
1. What is lactate and how does it affect exercise performance?
Lactate is a byproduct of the body's anaerobic energy production during exercise. It is produced when the body breaks down glucose for energy. High levels of lactate can lead to muscle fatigue and a decrease in exercise performance.
2. How does lactate contribute to muscle cramps?
Lactate buildup can cause a decrease in muscle pH, which can lead to muscle cramping. This is because changes in pH can affect the muscle's ability to contract and relax properly.
3. Can lactate be beneficial during exercise?
Yes, lactate can be beneficial during exercise as it can serve as an additional source of energy for the muscles. It can also help to remove excess hydrogen ions from the muscles, which can delay the onset of muscle fatigue.
4. How can athletes prevent cramping during exercise?
To prevent cramping during exercise, athletes should properly hydrate before, during, and after exercise. They should also make sure to warm up properly and gradually increase intensity to allow the body to adapt to the demands of the exercise.
5. Are there any supplements or treatments that can help with lactate and cramping?
Some studies have shown that certain supplements, such as beta-alanine, may help to buffer lactate and delay the onset of muscle fatigue. However, more research is needed in this area. Stretching, massage, and foam rolling may also help to prevent or relieve muscle cramps.
  • Biology and Medical
10K
22K
