Laps and Shift Function: Understanding the Role of t^a in Wald's GR Book (p.255)
  • Thread starter Thread starter paweld
    Function Shift
paweld
Could anyone explain me what is the interpretation of t^a filed in
Wald's GR book (p.255). It's defined as any (?) field which
fulfills condition t^a \nabla_a t, where t is "time function".
What is the difference between g^{ab}\nabla_b t
and t^a. Thanks for answer.
Hi,
Another way of stating t^a\nabla_a t=1 is that the Lie derivative of t along t^a equals 1. So Wald is just saying that the vector field t^a is properly normalized so that the function t changes at a constant rate of 1 along its integral curves. This normalization would be impossible to achieve if, for example, t^a were parallel to the Cauchy surfaces, as t would not change at all along its integral curves. The condition t^a\nabla_a t=1 makes sure that t^a is properly normalized as to generate time flow.
g^{ab}\nabla_b t is just equal to \nabla^at. This doesn't satisfy the above condition, since \nabla^at\nabla_a t\not=1 (not necessarily, at least).
Cheers,
Matthew
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
