Calculate Laser Burning Power Through Steel - Aragorn49
  • Thread starter Thread starter Aragorn49
    Laser Power
To determine if a laser can burn through steel, key factors include the laser's power in mW, wavelength, and the thermal properties of steel, such as melting and boiling temperatures. A DVD burner laser, typically maxing out at 400 mW, is insufficient for cutting through steel, as practical laser cutting requires power levels in the kilowatt range. For context, a 2W laser could only burn thin materials like black paper, while industrial lasers, such as a 50W CO2 laser, are used for engraving. The discussion emphasizes that small diodes are limited in their capabilities and cost. Understanding these variables is crucial for accurate calculations regarding laser material interactions.
Aragorn49
I would like to learn how to calculate whether a laser can burn through a material, or not. For example right now I need to calculate whether a laser from a DVD burner (which supposedly is max. 400 mW strong) can burn through steel.
I can imagine that I need to know the power of the laser in mW, the wavelength of the light it is emitting, the melting and boiling temperature and thermal conductivity of the material it is shining on. Also, I guess some optical properties will be important but I don't know which.
So far I gathered data on thermal properties of steel and other materials and power and wavelength of the laser.
Thank you very much for your help
Aragorn49
No way 400mW can burn steel lol!
All I can give you is experience. I had a 2W 445nm blue laser pointer focused into a 2*2mm dot. It could only burn black paper and black very thin plastic never achieving ignition.
Laser's to cut metal are in the order of kilowatts, I remember seeing a CO2 laser with 50W that was used just to engrave corks for wine.
With small diodes you can't do much, and even these cost around 100USD.
There are allot of variables, but I hope someone can give you a scientific answer.
Thank you very much for your help.
