Why is a probe field necessary in pump-probe experiments?
In summary, the pump-probe technique is commonly used in various experiments involving lasers. The pump field is used to excite the system to a desired state, while the probe field is used to measure the properties of the system. The probe field needs to be low energy in order to accurately control the environment. The probe field can cause the excited atom to return to ground state and emit light, or it can also excite the atom to upper state like the pump field does. This technique allows for high time resolution and can be used for various applications, such as measuring the transmission of a sample or the decay of spin polarization. Overall, the pump-probe technique is versatile and useful for a wide range of experiments.
KFC
488
In many paper or book on laser, it is quite oftern to mention the pump and probe field. I understand what the pump field is, but what about the probe field? What we need a probe field? How does it work (how to "probe")? And why a probe field is always a weak field?
The pump part of the experiment excites the system to a state that you want to measure. ie: if you want to measure a plasmon gas, the pump laser excites the gas, if you want to measure the ballistic electron scattering in graphite, the pump laser excites the electrons so that they CAN ballistically scatter.
The probe laser does the measuring. You focus it on the excited region and measure whatever properties are of interest. It needs to be low energy so that can confidently say you have controlled the environment with the pump laser.
Thanks. But how does it work? I wonder if the probe field will cause the excited atom to hop back to ground state so we can observed the emitted light? In addition, I wonder if probe field will also exicte the atom to upper state just like pump field does? What about if I choose the frequency of the probe field as the reasonant frequency of the system (take two-level system as example)?
Sure, that is possible.
That is possible, too. Generally speaking, pump-probe is a technique, which is useful for a whole bunch of experiments. It is very versatile and can be applied to a lot of situations, so there is no general answer to your questions, so let me just explain some examples.
In many - but not in all - experiments the transmission of the probe beam is of interest. So imagine you have a sample containing some two-level emitters, maybe atoms or quantum dots or whatever. Now you shine a weak pump pulse (resonant with some interesting transition) on that sample and measure the transmission. As you will see, most of the incoming pulse will be absorbed and there won't be much transmission. Now you turn on a strong pump beam, which is also resonant with the transition, but hits the sample under some angle, so that you do not measure the transmission of this beam. If the pump beam is strong enough, you will excite some of the two-level systems to the upper state. Accordingly, the transmission of the probe beam will increase, too, because there re now fewer atoms to excite. So compared to the first case, the differential transmission will have increased. If you choose an even large intensity for the pump beam, you might even see stimulated emission caused by the probe beam and therefore the intensity of the probe pulse after the sample will be higher than the bare probe beam alone. Now the really interesting thing is the high time resolution you can achieve with this kind of experiment.
If you use a strong pump beam, you might imagine that the excitation of the atoms has some temporal shape. The number of the atoms in the upper state will rise quickly and afterwards show some exponential decay due to spontaneous emission in most cases. Now you send the probe beam over some delay line so that you can change the relative time between the impact of the pump and the probe pulse. Now you scan the delay by moving the delay line and therefore get data about how many atoms are in the excited state at a time t after the pump pulse has arrived. As light is traveling so fast, you can get a time resolution in the femtosecond range by moving the delay line, which is one of the main advantages of this techniques.
As another application, you can also check, how fast spin polarization of an ensemble of two-level atoms decays. If you use a linearly polarized probe pulse, the polarization will be rotated proportionally to the strength of the magnetic field inside the matrial in between (Faraday rotation). So you can use a circularly polarized pump pulse to introduce some polarization of the spins inside the material, which will then undergo a free induction decay. Now you can again vary the arrival time of the linearly polarized probe pulse and check how much the polarization of the probe beam was rotated inside the sample and therefore you get to know the time dependence of the magnetic field inside the sample with high time resolution.
These are just two possible applications. In principle pump-probe techniques can be used any time, you can initialize some state and are able to get some information about this state by checking the transmitted light. Of course the probe must be weak compared to the pump. Otherwise the probe already changes the state you initialized drastically. If you use lock-in-amplifiers, you are even able to see very small effects.
Thank you soooooooooooooo much. It really helps.
FAQ: Why is a probe field necessary in pump-probe experiments?
1. What is a "pump & probe" laser field?
A pump & probe laser field is a technique used in spectroscopy and other scientific fields to study the dynamics of a system. It involves using two laser pulses - the pump pulse to excite the system, and the probe pulse to measure the response of the system.
2. How does a "pump & probe" laser field work?
The pump pulse is typically of higher energy and shorter duration than the probe pulse. It is used to excite the system and induce a change, such as a chemical reaction or phase transition. The probe pulse, on the other hand, is used to measure the response of the system to the pump pulse. By varying the time delay between the two pulses, scientists can observe the evolution of the system over time.
3. What types of systems can be studied using "pump & probe" laser fields?
Pump & probe laser fields can be used to study a wide range of systems, including molecules, atoms, solid materials, and biological systems. It is particularly useful for studying ultrafast processes, such as chemical reactions and phase transitions, that occur on the timescale of femtoseconds (10^-15 seconds).
4. What are the advantages of using "pump & probe" laser fields?
One of the main advantages of pump & probe laser fields is the ability to study ultrafast processes with high temporal resolution. It also allows for non-invasive measurements, meaning the system is not disturbed by the probe pulse. Additionally, this technique can provide information about the dynamics of a system, such as the rate of a reaction or the energy of a transition.
5. How is "pump & probe" laser field research used in practical applications?
Pump & probe laser fields have a wide range of practical applications in fields such as chemistry, physics, and materials science. For example, this technique can be used to study the mechanisms of photosynthesis and develop more efficient solar cells. It can also be used to study the dynamics of chemical reactions and improve the design of new drugs. Additionally, pump & probe laser fields are used in the development of ultrafast technologies, such as high-speed communication devices and ultrafast lasers.
10K
