Last 4 digits of a^1000 Prediction?
  • Thread starter icedsake
In summary, the conversation discusses the last 4 digits of a^1000 for a value between 2 and 10. The criterion for predicting these digits is using modulus and possibly Euler's Theorem or finding the order of a mod 10000. This would simplify the problem and avoid multiplying a 1000 times.
icedsake
for 2<= a <=10
what is the last 4 digits of a^1000?
What is the criterion for the prediction of the last 4 digits from a?
i am not sure
but it looks like a tailor series with calculating and error
use modulus when you divide a^1000 with 10000 ?
would there be a formula?
you don't know how modulus work?
Try using modulus and Euler's Theorem (if you're dealing with the prime a). Or you could try finding the order of a mod 10000 and using modulo arithmetic from there. That should reduce the problem to a much simpler one - at least, you won't have to multiply a out 1000 times.
1. What are the last 4 digits of a^1000?
The last 4 digits of a^1000 cannot be determined without knowing the value of 'a' as well as the method used to calculate the power of 1000.
2. Is there a formula to find the last 4 digits of a^1000?
There is no general formula to find the last 4 digits of a^1000, as it depends on the value of 'a' and the method used to calculate the power of 1000.
3. Can the last 4 digits of a^1000 be predicted?
Without knowing the value of 'a' and the method used to calculate the power of 1000, it is not possible to predict the last 4 digits of a^1000.
4. How can I find the last 4 digits of a specific value of a^1000?
To find the last 4 digits of a specific value of a^1000, you will need to know the value of 'a' and the method used to calculate the power of 1000. Then, you can use a calculator or computer program to calculate the power and determine the last 4 digits.
5. Are the last 4 digits of a^1000 always the same for any value of 'a'?
No, the last 4 digits of a^1000 can vary depending on the value of 'a' and the method used to calculate the power of 1000. There is no single answer for the last 4 digits of a^1000 for all values of 'a'.
