Comparing Op-Amp 741 and Latest Op-Amps
  • Thread starter Thread starter swty todd
    Op-amp
The discussion focuses on comparing the classic Op-Amp 741 with modern alternatives, highlighting key parameters such as noise and bandwidth. Participants suggest the OPA827 from Texas Instruments as a suitable low-noise option, while also mentioning the recently released OP77 from Analog Devices. The conversation emphasizes the importance of selecting the right op-amp based on specific project requirements. Users are encouraged to consider various performance metrics in their comparisons. Ultimately, the choice of op-amp can significantly impact project outcomes.
swty todd
have 2 make project which involves comparing op-amp 741 and anyone of the latest op-amps..can anyone suggest the any latest op-amp??
What are you going to compare? Noise? Bandwidth? Some other parameter?
OPA827 from TI is a new product that looks like a good op-amp for low-noise applications.
I just recently received some OP77 samples from AD. They just started production a month ago.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
