Latex: flushleft environment within tabular cells
  • Context: LaTeX
  • Thread starter Thread starter lavster
    Latex
The discussion focuses on issues encountered when using the flushleft environment within tabular cells in LaTeX, specifically when combined with the multirow package. Users reported errors such as "Missing \item" due to the list nature of flushleft. The recommended solution is to use \raggedright instead. Additionally, it is advised to avoid using the equation environment within tabular cells and to consider using the p column specifier or environments like parbox or minipage for better formatting.
  • Familiarity with LaTeX syntax and environments
  • Understanding of the multirow package in LaTeX
  • Knowledge of table formatting in LaTeX
  • Basic concepts of LaTeX error handling
  • Learn about using \raggedright in LaTeX for text alignment
  • Explore the p column specifier for tabular environments
  • Research the booktabs package for improved table design
  • Investigate the use of subcaption or subfig packages for labeling tables
LaTeX users, researchers preparing tables for academic papers, and anyone looking to improve their document formatting skills in LaTeX.
lavster
Can anyone tell me what is wrong with what I've written here - its coming up with lots of errors (inlcuded below). I have the \usepackage{multirow} at the beginning. Thanks
<br /> \begin{table}[h]<br /> \caption{Investigation of interleaf leakage using ion chamber}<br /> \begin{center}<br /> \begin{tabular}{c c c c}<br /> <br /> \hline\hline<br /> MLC open/closed &amp; Position from Original (mm) &amp; Reading (per 200MU) &amp; $\mbox{~~}$ Average $\mbox{~~}$ \\ [0.5ex]<br /> \hline\hline<br /> open &amp; 0 &amp; 4.27, 4.26 &amp; $\mbox{~~}$ 4.265 \\ <br /> closed &amp; 0 &amp; 0.49 &amp; <br /> \begin{flushleft}<br /> $$\mbox{~~}$$\ldelim \} {3} {7mm} \multirow{3}{*}{0.0493} <br /> \end{flushleft} <br /> \\<br /> <br /> closed &amp; 1 &amp; 0.50 &amp; \\ <br /> closed &amp; 2 &amp; 0.49 &amp; \\ [1ex]<br /> \hline<br /> \end{tabular}<br /> \label{rubbish}<br /> \end{center}<br /> \caption{Uncertainty of the Measurement}<br /> \begin{center}<br /> \begin{tabular}{c c}<br /> <br /> \hline\hline<br /> Source of uncertainty &amp; Uncertainty \\ [0.5ex]<br /> \hline\hline<br /> standard deviation &amp; see equation \ref{SD} \\ <br /> scale reading &amp; $\pm$0.01mm \\ <br /> response of electrometer &amp; $\pm$0.5\% \\ <br /> reproducibility of unit &amp; $\pm$1\% \\ <br /> <br /> \hline<br /> &amp; \\<br /> where, &amp; \\<br /> \multicolumn{2}{c}{<br /> \begin{equation}<br /> \mbox{~~~~~~~~~~~~~~~~~~~~~~~~~~~}StandardDeviation = \sqrt{\frac{\sum^{n}_{i=0}(x_i-\bar{x})}{n-1}},\mbox{~~~~~~~~~~~~~~~~~~~~~~~~~~~}<br /> \label{SD}<br /> \end{equation}<br /> } \\<br /> &amp; \\<br /> \multicolumn{2}{c}{where $\bar{x}$ is the average value, $x_i$ is the i-th reading and $n$ is the total number of readings.} \\<br /> \end{tabular}<br /> \label{uncert}<br /> \end{center}<br /> \end{table}<br /> <br /> [\tex]<br /> <br /> <br /> ! LaTeX Error: Something&#039;s wrong--perhaps a missing \item.<br /> <br /> See the LaTeX manual or LaTeX Companion for explanation.<br /> Type H &lt;return&gt; for immediate help.<br /> ... <br /> <br /> l.649 \begin{flushleft}<br /> <br /> Try typing &lt;return&gt; to proceed.<br /> If that doesn&#039;t work, type X &lt;return&gt; to quit.<br /> <br /> <br /> ! LaTeX Error: Something&#039;s wrong--perhaps a missing \item.<br /> <br /> See the LaTeX manual or LaTeX Companion for explanation.<br /> Type H &lt;return&gt; for immediate help.<br /> ... <br /> <br /> l.649 \begin{flushleft}<br /> <br /> Try typing &lt;return&gt; to proceed.<br /> If that doesn&#039;t work, type X &lt;return&gt; to quit.<br /> <br /> <br /> ! LaTeX Error: Something&#039;s wrong--perhaps a missing \item.<br /> <br /> See the LaTeX manual or LaTeX Companion for explanation.<br /> Type H &lt;return&gt; for immediate help.<br /> ... <br /> <br /> l.649 \begin{flushleft}<br /> <br /> Try typing &lt;return&gt; to proceed.<br /> If that doesn&#039;t work, type X &lt;return&gt; to quit.<br /> <br /> <br /> ! LaTeX Error: Something&#039;s wrong--perhaps a missing \item.<br /> <br /> See the LaTeX manual or LaTeX Companion for explanation.<br /> Type H &lt;return&gt; for immediate help.<br /> ... <br /> <br /> l.651 \end{flushleft}<br /> <br /> Try typing &lt;return&gt; to proceed.<br /> If that doesn&#039;t work, type X &lt;return&gt; to quit.<br /> <br /> <br /> ! LaTeX Error: Something&#039;s wrong--perhaps a missing \item.<br /> <br /> See the LaTeX manual or LaTeX Companion for explanation.<br /> Type H &lt;return&gt; for immediate help.<br /> ... <br /> <br /> l.651 \end{flushleft}<br /> <br /> Try typing &lt;return&gt; to proceed.<br /> If that doesn&#039;t work, type X &lt;return&gt; to quit.<br /> <br /> <br /> ! LaTeX Error: Something&#039;s wrong--perhaps a missing \item.<br /> <br /> See the LaTeX manual or LaTeX Companion for explanation.<br /> Type H &lt;return&gt; for immediate help.<br /> ... <br /> <br /> l.651 \end{flushleft}<br /> <br /> Try typing &lt;return&gt; to proceed.<br /> If that doesn&#039;t work, type X &lt;return&gt; to quit.<br /> <br /> ! Missing $ inserted.<br /> &lt;inserted text&gt; <br /> $<br /> l.680 }<br /> \\<br /> I&#039;ve inserted a begin-math/end-math symbol since I think<br /> you left one out. Proceed, with fingers crossed.<br /> <br /> ! You can&#039;t use `\eqno&#039; in math mode.<br /> \endmathdisplay@a ...\df@tag \@empty \else \veqno <br /> \alt@tag \df@tag \fi \ifx ...<br /> l.680 }<br /> \\<br /> Sorry, but I&#039;m not programmed to handle this case;<br /> I&#039;ll just pretend that you didn&#039;t ask for it.<br /> If you&#039;re in the wrong mode, you might be able to<br /> return to the right one by typing `I}&#039; or `I$&#039; or `I\par&#039;.<br /> <br /> ! Missing $ inserted.<br /> &lt;inserted text&gt; <br /> $<br /> l.680 }<br /> \\<br /> I&#039;ve inserted something that you may have forgotten.<br /> (See the &lt;inserted text&gt; above.)<br /> With luck, this will get me unwedged. But if you<br /> really didn&#039;t forget anything, try typing `2&#039; now; then<br /> my insertion and my current dilemma will both disappear.
also how to I insert my text properly?!
For properly inserting code, use the "Code" button in the post editor.
Regarding the problem: you cannot use a flushleft environment within tabular cells. It's implemented as a list environment, that's why you got the error "Missing \item" because a list consists of items. You could use \http://latex-community.org/know-how/latex/55-latex-general/424-latex-reference-manual#g_t_005craggedright instead.
Also, you cannot use an equation environment within a normal tabular cell. It would work in a paragraph cell, made with the p column specifier, or within \parbox or a minipage environment.
Further tipps:
  • Use more table placement options, such as [!htbp] instead of just [h], to allow more flexible placement. You can find an explanation of these options on LaTeX-Community.org in the post Order of appearance of tables and figures
  • I would not use a center environment within in a table environment, this adds additional vertical space. Instead, I would use \centering. See center vs. \centering for an explanation.
  • \mbox{~~~~~~~~~~~~~~~~~~~~~~~~~~~} and similar are strange fixes - you could use http://latex-community.org/know-how/latex/55-latex-general/424-latex-reference-manual#g_t_005chspace but better would be a proper automatic alignment.
  • Several labels in a table environment could be a problem - perhaps use the subcaption or the subfig package.
  • I strongly recommend to use the booktabs package for nice table design.
Stefan
  • · Replies 0 ·
  • · Replies 16 ·
