Find the Lattice Constant of Atoms - Get Help Now!
In summary, the lattice constant refers to the constant distance between unit cells in a crystal lattice. Lattices in three dimensions generally have three lattice constants, referred to as a, b, and c. However, in the special case of cubic crystal structures, all of the constants are equal and we only refer to a. In order to find the lattice constant for a diamond structure (such as GaAs, GaN, or Si), you can use the geometric properties of a tetrahedron to determine the nearest neighbor spacing. Alternatively, you can also use x-ray diffraction techniques to experimentally determine the lattice constant.
JoshHolloway
222
Will someone please give me a link that explains how to find the "lattice constant" of certain atoms.
Or could someone please walk me through the process of how you find the lattice constants. Thanks in advance:smile:
There is many different things called the lattice constant. What course is this in? Solid state physics??
Yep. It is semiconductor physics.
The "lattice constant" is not a property of atoms. It is a property of crystal lattices - i.e., periodic arrangements of atoms in three dimensions. Basically, the lattice constant is the length of periodicity of the lattice, i.e., the minimum distance at which the lattice repeats itself. For most crystals the lattice constant(s) is few angstroms.
Eugene.
What are you given? If someone just names a crystalline element/compound and asks you to determine the lattice parameters, that's essentially a nonsense question (unless looking up a reference counts as "determining").
If you know the chemical composition, the pure state density and crystal structure, then you may be able to determine it's lattice parameters to some reasonable accuracy.
I'll post an example of what I am talking about tommorow.
okay, but x-ray diffraction etc in many different directions can give you information about distances between planes. All these techniques are written in almost all intro- solid state physics books. Iam doing a course about this now, so my memory is fresh ;)
Okay, here is the definition of the lattice constant I am referring to:
The lattice constant refers to the constant distance between unit cells in a crystal lattice. Lattices in three dimensions generally have three lattice constants, referred to as a, b, and c. However, in the special case of cubic crystal structures, all of the constants are equal and we only refer to a.
So how would I find the lattice constant of Si (of course in the diamond structure).
It seems to me that you would need to know the radius of the atom to find the lattice constant.
great!
Then the metod for obtaing in experimentally is by doing x-ray diffraction. This thing is covered in almost all basic Solid State physics books, such as Kittel for example.
Just google a bit if you want, there is plenty of sites that contains info. Other keywords is Bragg diffraction.
maybe this site has info too
http://freescience.info/index.php
Do you want to calculate it theoretically or experimentally? What are given in your problem etc..
Yeah, I want to calculate it theoretically.
OK, here is an example:
Given:
The dimensions of a diamond structure unit cell are (length, width, height) = (a,a,a).
Find:
The lattice constant for the diamond structure.
why not "a" ?..
a is not the distance of the two closest atoms.
but that is not the definition for lattice constant?
your post #8
"The lattice constant refers to the constant distance between unit cells in a crystal lattice. Lattices in three dimensions generally have three lattice constants, referred to as a, b, and c. However, in the special case of cubic crystal structures, all of the constants are equal and we only refer to a."
Your post #11
"The dimensions of a diamond structure unit cell are (length, width, height) = (a,a,a)"
Ya, you are right. Huh...
I found that definition on the internet, so that is not the definition my book uses. In fact the lattice constant is not even defined in my book! (It is Neaman's Semiconductor device physics).
But I am trying to figure out the distance between the two closest atoms in a unit cell.
ahh okay...
well that depends on what definition you have of distance between to atoms, atoms are not "hard" objecs you know..
But if we assume they are hard spheres, then with equal radius, the closest distance should be 0 if as closed packed as possible. Atoms at 000 and (1/4)(1/4)(1/4) are in contact. Are you sure you are not looking for the second closest distance?
Yeah, I am looking for the second closest distance, sorry.
malawi_glenn said:
ahh okay...
Typically, this refers to the center to center distance. For instance, in a simple cubic, the nearest neighbor spacing is the same as the lattice parameter, a; in a BCC, it is [itex]a \sqrt{3}/2 [/itex], etc.
For any given crystal structure, you need to first draw the unit cell and the ratio of nearest-neighbor spacing to lattice parameter can be determined geometrically.
PS: Almost no one ever wants to know the second closest (next nearest neighbor) spacing.
Yeah gokul, that is exactly what I am talking about.
So, for the case of the diamond structure (GaAs, GaN, Si, etc.), the answer is almost already in mg's post#16 : If you know that (0,0,0) and (1/4,1/4,1/4) are the locations of neighboring atoms, then the nearest neighbor spacing [itex]d_{nn}=a\sqrt{(1/4)^2 + (1/4)^2 +(1/4)^2 } = a\sqrt{3}/4 [/itex]
If you do not know the positions of atoms in the unit cell, then it's a few steps longer:
1. Refer to this picture: http://images.google.com/imgres?img...ges?q=diamond+cubic+&svnum=10&um=1&hl=en&sa=N
2. Notice that neighboring atoms are tetrahedrally arranged, with one atom at the vertex and the other at the centroid of the tetrahedron.
3. The centroid of any pyramidal/conical shape is located at 3h/4 from the vertex along the symmetry axis (h is the height).
4. The height of a tetrahedron in [itex]h=\sqrt{6}s/3 [/itex], where s is the side of the tetrahedron.
5. Finally, notice that the other vertices of the tetrahedron lies on face centers, so [itex]s=a/\sqrt{2} [/itex].
Put these together and see that you get the same result as above.
I'm doing the same type of course with the same exact textbook. I have a question that states "Assume that the radius of an atom is 1.90 in Angstroms and that it can be represented as a hard sphere. Give the lattice constant, in Angstroms, if the atom is placed on a diamond lattice"
For a simple cubic or body centred cubic lattice it isn't that hard, but I'm not sure how to calculate for a diamond lattice because of the different layout of atoms inside the lattice.
1. What is the lattice constant of an atom?
The lattice constant of an atom is the distance between two adjacent atoms in a crystal lattice. It is measured in units of length, such as angstroms or nanometers.
2. Why is it important to determine the lattice constant of atoms?
Determining the lattice constant is important for understanding the structural properties of materials. It can also help in predicting the physical and chemical properties of a material, which is crucial in many scientific fields such as materials science and solid state physics.
3. How is the lattice constant of atoms measured?
The lattice constant can be measured experimentally using techniques such as X-ray diffraction or electron microscopy. It can also be calculated using theoretical models and equations based on the crystal structure of the material.
4. Can the lattice constant of atoms vary within a material?
Yes, the lattice constant can vary within a material depending on factors such as temperature, pressure, and the presence of impurities. This can affect the material's properties and behavior.
5. What are some common techniques for finding the lattice constant of atoms?
Some common techniques include X-ray diffraction, transmission electron microscopy, and scanning probe microscopy. These techniques can provide precise measurements of the lattice constant at different scales.
  • Quantum Physics
  • Linear and Abstract Algebra
