Law of conservation of momentum question
The discussion revolves around a physics problem involving the law of conservation of momentum related to an asteroid impact on Earth. The user calculated the Earth's recoil speed after the collision to be approximately 668.896 m/s. They also determined the Earth's orbital speed around the sun to be about 4756.47 m/s, leading to an initial calculation of 14% for the recoil speed as a percentage of the orbital speed. However, it was pointed out that the user needed to account for the circumference of Earth's orbit by multiplying the mean radius by 2π, which corrected the percentage to approximately 2.2%. The user confirmed the accuracy of this revised calculation.
physics120
Most geologists believe that the dinosaurs became extinct 65 million years ago when a large comet or asteroid struck the earth, throwing up so much dust that the sun was blocked out for a period of many months. Suppose an asteroid with a diameter of 2.0km and a mass of 1.0*10^13 kg hits the Earth with an impact speed of 4.0*10^4 m/s.
a) What is the Earth's recoil speed after such a collision? (Use a reference frame in which the Earth was initially at rest.)
b) What percentage is this of the Earth's speed around the sun?
I used the law of conservation of momentum (Pf = Pi) This states that the total momentum after an interaction is equal to the total momentum before the interaction.
a) Using Pf=Pi, I solved for the final velocity, which is the same for both the Earth and the asteroid, and got 668.896 m/s. (The final velocity is the Earth's recoil speed)
b) NOW for this part, I got from my textbook that the "earth's mean distance from sun (m) = 1.50*10^11 m. Also, I got that the Earth's period (years) = 1.00 years
Using these, I found the speed to be 4756.468798 m/s by converting years to seconds and dividing the two numbers (to get m/s)
Then,
(668.896m/s / 4756.4688798m/s) * 100% = 14%
Did I do this correctly? Did I use the correct numbers from my textbook to get the speed?
Please help!
Thank-you
The data from your book is correct, but it appears that you forgot to multiply by 2pi! That number you have is the mean radius. If we assume the orbit is roughly circular, we multiply it by 2pi so we can get the circumference - THAT is the distance the Earth travels in a year.
I see! So I tried it again and found the circumference. Is it 2.2% for the percentage of the Earth's speed around the sun?
Thank-you, by the way!
Yup, that's correct! and no problem.
