Law of Transformers: A.C Source & Induced EMFs
  • Thread starter Thread starter B4ssHunter
    Law Transformers
The discussion centers on the application of the law of the transformer, specifically regarding the primary and secondary coils. In the primary coil, the voltage is supplied by an external AC source rather than being induced, which raises questions about the law's applicability. The primary coil's voltage comprises both the induced voltage and the voltage required to drive the current through the wire. It is clarified that the induced voltage acts as a voltage drop opposing the current flow, similar to how resistors operate. The phenomenon of back EMF is highlighted as a key concept in understanding the interactions within coils and transformers.
B4ssHunter
the law of the transformer states that
in primary coil , the EMF = -n multiplied by the rate of change of flux with respect to time
but that law applies to induced EMFs , and since the voltage in the primary coil is not actually induced but rather produced by an external source of A.C , then how can we apply the rule to such a thing ? in the secondary the voltage is purely induced so the law does apply , but in the primary coil the potential difference is not induced .
It's the same thing as in the other thread. The voltage across the primary is going to be the sum of the induced voltage and the voltage needed to drive the given current through the wire. The induced voltage works exactly the same way in both coils, but in primary it's the back EMF, while in secondary, it's EMF for whatever that coil is driving.
If it makes it simpler for you, you can always think of a real coil as a perfect, zero resistance inductor and a resistor in series. Resistor is just ohmic, giving voltage drop equal to IR, while the inductor portion gives just the induced voltage proportional to the rate of change of magnetic flux.
oh , so the inductor voltage just acts as a voltage drop , i never knew that a voltage drop was opposing the current :D thanks a lot , made lots of things clear
there is voltage drop on resistor for example and it doesn't produce a opposite current flow.It just opposes current , but that is a different thing, in a resistor the current flow produces interactions at the subatomic level which manifest themselves as heat , in the case of a back EMF a field works against the charged particle flow ,current.voltage drop isn't responsible for current reversal , in an inductor or transformer and also in electric motors , there is a phenomenon called back EMF , in other words when you add a potential difference to a coil , it causes current to flow , that current has a magnetic field around it which when changing in both magnitude and direction creates a changing electric field which opposes the original current flow magnetic field that created it.
actually member K2 answers this in your other post quite nicely.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
13K
