How can the added inductors and capacitor in this LC circuit create a harmonic?
The discussion focuses on understanding how added inductors (L3, L4) and a capacitor in an LC circuit create harmonics. The circuit can react to input signals, producing varying results based on input frequency and the specific input/output nodes used. A series tuned circuit resonates at approximately 6 MHz, while a parallel resonance peak occurs around 3.2 MHz, with a series resonance null at about 6.2 MHz. The use of LTSpice is recommended for simulating these behaviors and gaining familiarity with circuit analysis. Understanding these dynamics is crucial for calculating the harmonics generated by the circuit.
drewblank
I'm trying to better understand this circuit:
https://www.circuitlab.com/circuit/qnxkke/lc-chopper/
and how the added inductors (L3, and L4) and Capacitor create a harmonic. I fully understand how to calculate the resonance for the main circuit but how would I calculate the harmonic that the added circuit creates?
What are the input and output nodes of the circuit?
This circuit cannot generate anything. It can react to input signals and give different results depending on the input frequency.
The result also depends on where you feed an input signal in, and where you look at the output.
Roughly, this is a series tuned circuit resonant at about 6 MHz in parallel with a parallel resonant circuit at 6 MHz.
I added a sinewave signal source in series with a 10K resistor across the series tuned circuit and got a parallel resonance (a peak) at about 3.2 MHz and a series resonance (a null) at about 6.2 MHz measured in the same place.
This was using LTSpice, a free program which I urge you to get familiar with.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
