Leading Power Factor - Voltage drop
Generators operating at a leading power factor reduce voltage drop, while those at a lagging power factor increase voltage rise. The source and sink of VARs (volt-ampere reactive) significantly influence voltage levels, as the generator's output voltage can be adjusted. When the voltage is increased, VARs flow out of the generator, and when decreased, they flow into it. Maintaining a nominal output voltage is essential, as the direction of reactive power primarily depends on the system load. Understanding these dynamics is crucial for effective voltage management in power systems.
scothoward
Hi, I am hoping you can help me understand this concept.
I've always known that generators operating a leading power factor lowers voltage drop and a lagging power factor increases voltage rise (as seen here: http://books.google.ca/books?id=nIc... generator at a leading power factor"&f=false ), but never understood why.
How does the source/sink of VARs affect voltage rise/drop?
Thanks
(That link doesn't work for me: "You have reached you viewing limit..." etc)
scothoward said:
I've always known that generators operating a leading power factor lowers voltage drop and a lagging power factor increases voltage rise... but never understood why.
I believe that the generators output voltage can be controlled. When the voltage is raised, VARs will be out of the generator and when it's lowered, VARs will be into the generator. But the output voltage would have to be kept a some nominal value so I guess the direction of the reactive power depends mostly on the system load.
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
