MATLAB Learn How to Perfectly Shuffle Vectors in Matlab with Simple Pseudo-code"
  • Thread starter Thread starter phillyj
    Matlab Vectors
The discussion focuses on how to perfectly shuffle a vector in MATLAB by splitting it in half and interleaving the elements. A user seeks help with pseudo-code for this task, providing an example with the vector [1 2 3 4 5 6], which should be rearranged to [1 4 2 5 3 6]. Several users suggest methods, including using a for loop to assign values to a new vector, while others propose reshaping techniques to achieve the same result without loops. The conversation highlights the challenge of implementing the shuffle without prior knowledge of loops, and the importance of understanding vector dimensions in MATLAB. Ultimately, the thread emphasizes collaborative problem-solving in coding challenges.
phillyj
I'm having trouble understanding how to do a perfect shuffle of a vector. I'm supposed to split the vector in half then the 1st element is the 1st element in the first half and the 2nd element is the 1st element of the 2nd half, and so on.
For example, if I have [1 2 3 4 5 6]
then I need to rearrange it into [1 4 2 5 3 6]
Can someone at least help me with the pseudo-code? I been thinking about this a few days with no luck. I am only allowed a few functions like "find" or "length". Nothing complex.
bah, messed up. I figured this out a couple months ago. Will repost once I confirm.
%it has to be an even length vector, but:
N = length(x)/2
y = zeros(N,1)
for n = 1:N
y(2*n-1) = n
y(2*n) = N+n
end
Can you do this without using for loops? We haven''t covered that yet. I may have to ask the professor. Its surprising because even the TA had no clue how to do this with the material we have covered so far.
Thanks
Wow, I can't thing of how you do this without a loop unless you exacty knew your input.
If I have any insights, I'll share them with you.
I like pythag's answer better, but something like this would work.
A=[1,2,3,4,5,6]
B=reshape(A,[3,2])
C=reshape(B',[1,6])
Probably other ways of doing it using the reshapes and row/column swaps, etc.
N = length(x)/2
y = zeros(N,1)
for n = 1:N
y(2*n-1) = n
y(2*n) = N+n
end
Can you explain this to me since I never used loops before? Also, any particular reason why you specify Nx1 zero vector rather than 1xN vector?
A for loop just goes through all the lines between FOR and END, changing the specified value every time, so you can base your code on that evolving number.
1xN or Nx1 is arbitrary in general. You may have a specific preference depending on the rest of your code. They're equivalent though in the absence of conflicting comparisons.
Hi,
your problem can be solved by this way
%let c be the vector which has to be rearranged
% assuming size of c to be even
c=1:10;
% d is the vector where we store the rearranged vector
d = zeros(size(c));
d(1:2:end) = c(1:end/2);
d(2:2:end) = c(end/2+1,end);
%thats all you need to do ;)
Hope it will help!
Chhitiz
http://www.chhitizbuchasia.com"
