Learn Mandatory LaTeX with PF: A Step-by-Step Guide
  • LaTeX
  • Thread starter Greg Bernhardt
In summary: WarrenIs it working now?- Warren\psilooks like it works; good job!- WarrenIn summary, PF is implementing LaTeX on PF with the use of a new bbcode [ tex][ /tex] or [ latex][ /latex], allowing members to use LaTeX code within the tags to display equations. Additional features include a popup window for displaying code, and the ability to use macros. However, there may be some issues with image generation and server speed.
  • #36
Originally posted by enigma
Should we be worried if it gives the "Latex image is being generated, please reload" message?
Perhaps... I'm not sure what's hanging it up. I'm trying to figure that out now... eek.
- Warren
  • #37
[tex]
\frac{1}{2}
[/tex]
  • #38
Argh... all of a sudden the server seems to be having a problem...
- Warren
  • #39
[tex]
\frac{3}{4}
[/tex]
  • #40
I just looked through the lists.
Are there commands for double and triple integral as well as surface and volume integral symbols?
  • #41
looks like we bogged the server down, once it's fixed we'll open up testing again.
  • #42
Woohoo... sorry about the mistake guys.
[tex]\gamma \equiv \frac{1}{\sqrt{1 - v^2/c^2}}[/tex]
- Warren
  • #43
Do your worst, fellas... let's see if I forgot to do anything else.
- Warren
  • #44
[tex]\alpha[/tex]
[tex]\beta[/tex]
[tex]\gamma[/tex]
  • #45
I tried this one as an edit to a previous post, and it did not work there upon reloading.
[tex]
\psi
[/tex]
  • #46
A psi doesn't work?
[tex]\psi[/tex]
  • #47
What I typed up there was "\psi"; instead, I see what I would have expected afger typing "\alpha".
I guess I'll just have to wait a little longer.
  • #48
[tex]\int\!\!\!\int f(x,y)\,dx\,dy[/tex]
[tex]\int\!\!\!\int\!\!\!\int f(x,y,z)\,dx\,dy\,dz[/tex]
[tex]\oint_C f(x,y)\,d\sigma[/tex]
  • #49
okay, let's try
[itex]
$\Delta V_{(R_{1}\rightarrow R_{2})}= V_{R_{1}}\left[\sqrt{\frac{2R_{2}}{R_{1}+R_{2}}}-1 \right]$ [/itex]
  • #50
Originally posted by chroot
A psi doesn't work?
[tex]\psi[/tex]
Apparently.
  • #51
Yeah something is weird...
this
[tex]
\psi
[/tex]
is different from this
[tex]\psi[/tex]
and it shouldn't be.
- Warren
  • #52
There we go!
[tex]B_0 \rightarrow J\psi K^0_s[/tex]
  • #53
The server is trying to confuse us all! :smile:
Now you see it, now you don't, now you complain, now it's ok, it looked different just a minute ago...
  • #54
The reason is looks wacky is simple:
1) Some graphics take longer than others to create; they're all in background processes. Sometimes, you view the thread at first, but your graphics are not done yet.
2) When a graphic is not present (because it is not done being generated), the stupid webserver will try to help you out by sending you another graphic with a similar filename. It's supposed to help you avoid 404 errors for spelling mistakes. I really hate this "feature," because in this case, it results in your post showing someone else's graphics temporarily until yours are done!
I'm going to fix this in a few minutes.. hold on.
- Warren
  • #55
Okay, let's try this. This should fix the weirdness.
[tex]
\Delta V = - I_{sp} \times g_0 \times \ln{\frac{M_L + M_i}{M_L + M_i + M_P}}
[/tex]
- Warren
  • #56
This stuff looks GREAT! Let's have a go at it
[tex]\int_{-\infty}^{\infty}[/tex]
[tex] \stackrel \cdot x[/tex]
[tex] \ddot{x} = -g[/tex]
[tex]\int \ddot{x}dt = \int -gdt[/tex]
[tex]\dot{x} = -gt + C[/tex]
[tex] \dot{x}(0)= V_0 \Rightarrow C = V_0[/tex]
[tex]\int \dot{x}dt = \int -gt + V_0 dt[/tex]
[tex]x(t)= - \frac {gt^2} {2} + V_0t + X_0 [/tex]
[tex]\mbox{ x=y} \mbox{\iff |x-y| < \epsilon} \forall \mbox{ \epsilon \in \Re}[/tex]
[tex]\ddot{x} = \frac {d^2x} {dt^2}[/tex]
  • #57
[tex]
\begin{pmatrix} D_1t&-a_{12}t_2&\dots&-a_{1n}t_n\\
-a_{21}t_1&D_2t&\dots&-a_{2n}t_n\\
-a_{n1}t_1&-a_{n2}t_2&\dots&D_nt
\end{pmatrix}
[/tex]
  • #58
[tex]\frac{a}{b}[/tex]
  • #59
[tex]
\int\!\!\!\int\!\!\!\int f(u,v,w)\,du\,dv\,dw
[/tex]
  • #60
[tex]\mu[/tex]
[tex]\nu[/tex]
[tex]\xi[/tex]
[tex]\phi[/tex]
  • #61
[tex]g_{\mu\nu}[/tex]
  • #62
[tex]
\int_{0}^{1} x dx = \left[ \frac{1}{2}x^2 \right]_{0}^{1} = \frac{1}{2}
[/tex]
[tex]v(t) = v_0 + \frac{1}{2} a t^2[/tex]
[tex]
\int_{0}^{1} y dy = \left[ \frac{1}{2}y^2 \right]_{0}^{1} = \frac{1}{2}
[/tex]
[tex]
\int_{0}^{1} z dz = \left[ \frac{1}{2}z^2 \right]_{0}^{1} = \frac{1}{2}
[/tex]
  • #63
Test.
  • #64
[tex]
[/tex]
[tex]
[/tex]
[tex]
[/tex]
  • #65
[tex]
\int_{0}^{1} u du = \left[ \frac{1}{2}u^2 \right]_{0}^{1} = \frac{1}{2}
[/tex]
[tex]
\int_{0}^{1} v dv = \left[ \frac{1}{2}v^2 \right]_{0}^{1} = \frac{1}{2}
[/tex]
[tex]
\int_{0}^{1} w dw = \left[ \frac{1}{2}w^2 \right]_{0}^{1} = \frac{1}{2}
[/tex]
  • #66
  • #67
[tex]
[/tex]
[tex]
[/tex]
[tex]
[/tex]
  • #68
  • #69
Okay guys...
Keep playing with the LaTeX stuff.
At the moment, it seems like newreply.php sometimes doesn't work quite right, but I can't identify the situations where it fails just yet.
If you post a new reply and something doesn't work right, hit edit, then save, and it should be fine. I'm going to look into the problem soon.
In the meantime, practice LaTeX and let me know what you find.
- Warren
  • #70
Let's see,
The third Pauli matrix is
[tex]/sigma_{3} = \left(\begin{array}{cc}1&0\\0&-1\end{array}\right}
  • STEM Academic Advising
  • Feedback and Announcements
  • Sticky
183K
