Mathematica Learning how to compute Christoffel symbols using Mathematica
The discussion revolves around calculating the Christoffel symbols using a specific metric tensor in a mathematical code environment. The user initially struggled with missing components in their calculations, particularly the InverseMetric function, which was not defined. After defining it, they managed to compute some symbols but still faced issues retrieving specific values, such as ##\cot(\theta)##. The user shared their code and sought assistance in correctly calling the Christoffel symbols. Eventually, they clarified their approach by defining the Christoffel symbol function properly and ensuring the metric and coordinates were correctly specified. They successfully retrieved the desired symbols, demonstrating a learning process in using the code effectively for general relativity calculations.
JD_PM
TL;DR Summary
I want to compute the Christoffel-symbol for a given metric.
I am using the code provided by Artes here, but I am missing something.
The Chrisfoffel-symbol formula is
$$\Gamma^{\mu}_{\phantom{\mu}\nu\sigma}=\frac{1}{2}g^{\mu\alpha}\left\{\frac{\partial g_{\alpha\nu}}{\partial x^{\sigma}}+\frac{\partial g_{\alpha\sigma}}{\partial x^{\nu}}-\frac{\partial g_{\nu\sigma}}{\partial x^{\alpha}}\right\}\quad$$
The metric is given to be$$
g_{\mu \nu} =
\begin{pmatrix}
1 & 0 & 0 & 0 \\
0 & r^2+b^2 & 0 & 0 \\
0 & 0 & (r^2+b^2)\sin^2(\theta) & 0 \\
0 & 0 & 0 & -1
\end{pmatrix}
The provided solution is:
$$\Gamma^{1}_{22}=-r$$
$$\Gamma^{1}_{33}=-r\sin^2(\theta)$$
$$\Gamma^{2}_{21}=\frac{r}{b^2+r^2}$$
$$\Gamma^{2}_{33}=-\cos(\theta)\sin(\theta)$$
$$\Gamma^{3}_{31}=\frac{r}{b^2+r^2}$$
$$\Gamma^{3}_{32}=\cot(\theta)$$
The code I'm using is
Code:
    xx = {t, x, \[Theta], \[Phi]};
    g  = { {1,0,0,0},
       {0,r^2+b^2,0,0},
       {0,0,(r^2+b^2)Sin[\[Theta]]^2,0},
       {0,0,0,-1}};
    ChristoffelSymbol[g_, xx_] :=
        Block[{n, ig, res},
               n = 4; ig = InverseMetric[ g];
               res = Table[(1/2)*Sum[ ig[[i,s]]*(-D[ g[[j,k]], xx[[s]]] +
                                                  D[ g[[j,s]], xx[[k]]]
                                                + D[ g[[s,k]], xx[[j]]]),
                                      {s, 1, n}],
                           {i, 1, n}, {j, 1, n}, {k, 1, n}];
               Simplify[ res]
But I get
What am I missing? Besides, I'd like to learn how could I display the answer (once I know how to actually get it of course).
Any help is appreciated.
Thank you :smile:
Likes etotheipi
What is InverseMetric?
Likes JD_PM
Oh I did not define the InverseMetric! Thanks for pointing it out.
I now have
Code:
g = { {1,0,0,0},
{0,r^2+b^2,0,0},
{0,0,0,-1}};
InverseMetric=Simplify[Inverse[g]]
Block[{n, ig, res},
n = 4; ig = InverseMetric;
         {s, 1, n}], {i, 1, n}, {j, 1, n}, {k, 1, n}];
    Simplify[ res]
ChristoffelSymbol[g, xx]
I now get
So apparently I only get ##\Gamma^3_{32}##
I found an alternative here
Code:
Clear [coord, metric, inversemetric, affine]
n = 4;
coord = {t, x, y,z};
metric = { {1,0,0,0}, {0,r^2+b^2,0,0}, {0,0,(r^2+b^2)Sin[\[Theta]]^2,0},
  {0,0,0,-1}};
inversemetric = Simplify[Inverse[metric]];
affine :=
  affine = Simplify[
Table[(1/2)*
Sum[inversemetric[[i,
s]]*(D[metric[[s, j]], coord[[k]]] +
D[metric[[s, k]], coord[[j]]] -
D[metric[[j, k]], coord[[s]]]), {s, 1, n}], {i, 1, n}, {j,
      1, n}, {k, 1, n}]];
listaffine :=
  Table[If[UnsameQ[affine[[i, j, k]],
0], {ToString[\[CapitalGamma][i - 1, j - 1, k - 1]],
affine[[i, j, k]]}], {i, 1, n}, {j, 1, n}, {k, 1, j}];
TableForm[Partition[DeleteCases[Flatten[listaffine], Null], 2],
TableSpacing -> {2, 2}]
I am struggling now in how to call out the specific Christoffel symbols correctly; I am trying
Code:
affine[[3,3,2]]
But I get zero instead of ##\cot(\theta)##; the same happens to me with other non-zero terms.
Likes Ishika_96_sparkles and JD_PM
OK I understand how to do it now! :smile: (more details)
My issue was in how to call out the function. Let's go step by step:
1) Define the Christoffel symbol function:
Code:
     Block[{n, ig, res}, n = Length[xx]; ig = Inverse[g];
      res = Table[(1/2)*
         Sum[ig[[i, s]]*(-D[g[[j, k]], xx[[s]]] + D[g[[j, s]], xx[[k]]] +
             D[g[[s, k]], xx[[j]]]), {s, 1, n}], {i, 1, n}, {j, 1, n}, {k,
          1, n}];
      Simplify[res]]
2) Define the coordinates and the components of the metric wrt the coordinate basis
Code:
    (* The coordinates *)
    xx = {r, \[Theta], \[Phi], t};
    (* The metric *)
    g = {{1, 0, 0, 0}, {0, r^2 + b^2, 0, 0}, {0,
        0, (r^2 + b^2) Sin[\[Theta]]^2, 0}, {0, 0, 0, -1}};
3) Relabel the Christoffel symbol function so that you can call out specific Christoffel symbols
Code:
    sol = ChristoffelSymbol[g, xx] (* This calls the function! *);
    sol[[1, 2, 2]](*for instance*)
    (* -r *)
Gen. Relativity... :cool:
got my answer.
Likes JD_PM
