bhsmith
- 37
- 0
I'm having a hard time understanding length contraction. can anyone explain it to me in simple terms?
stevmg said:I think length contraction was initially proven by the 1888 experiment of Michelson-Morley.
Go https://www.physicsforums.com/blog.php?b=1959 for an explanation by starthaus "MMX.pdf."
Later backed up by Lorentz-?Fitzgerald?
psmitty said:No, MMX doesn't have anything to do with length contraction. Check https://www.physicsforums.com/showthread.php?t=229034". At this point there are no direct experimental proofs of length contraction.
This is not quite right either if I understand you correctly. The observer in the stationary frame (the frame at rest with the track that does that does not accelerate) will measure the train to be shorter than 100m when it has velocity relative to the track. The observer onboard the train will still measure the length of the train to be 100m after it has accelerated and returned to inertial motion and after he has resynchronised all his clocks. The observer on the train after it has accelerated will measure objects at rest with the track to length contracted.psmitty said:Actually, if I got it right: if a train is 100m long at rest in the stationary frame, it will still be 100m long when it starts to move, when observed from the stationary frame. But the observer in the train will experience contracted lengths along the path of movement.
starthaus said:This is false, in the frame of an observer wrt which the Earth (with the lab and the MMX setup) are moving, length contraction is the correct explanation of the null result.
In the frame of the lab, the isotropy of light speed is the explanation of the null result.
stevmg said:No, MMX doesn't have anything to do with length contraction.
Check this thread. At this point there are no direct experimental proofs of length contraction.
Of course textbook explanations and your blog on MMX referred to above establish this.
stevmg
. I understand your MMX.pdf quite well.
stevmg said:starthaus -
I was backing you... Your blog makes that point. My previous post must have been a quote without the. I understand your MMX.pdf quite well.
I see, you can go back and edit your post to fix that.
stevmg said:SH
Check it out (post 10) again - it looks right now but I am not used to going back before the last post to edit a prior post and the subsequent replies may be based on the "wrong" info in the that prior post.
SMG
