kev said:
Oddly enough, if the telescope is moving at relativistic velocities towards a distant galaxy, the galaxy would appear smaller (and further away) due to abberation effects. On the other hand, the photons arriving at the film or ccd backplate of the telescope would appear to be arriving at a higher rate per second, so the the galaxy would appear to be brighter and smaller at the same time. There would also be a Doppler effect that makes the photons seem more energetic or shifted towards the blue end of the spectrum. (i.e. the wavelength of the photons appears shorter.) The light that the telescope "has access to" remains the same, whatever the relative velocity of the telescope is to the source. It just sees the light in a different way.
I guess the more distant galaxies would become visible due to blue-shift counteracting the red-shift caused by universal expansion.
It also seems that the speed of universal expansion can never exceed the speed of light in the frame of two galaxies moving in relation to each other. That lends more support to my belief that dilation is compensation for the relative limit of C, in that the two galaxies expanding away from each other would have to be approaching C and, in addition to red-shifting, the speed of light between those two galaxies would have to be faster than between two galaxies expanding apart at slower relative speed.
Another way to put it would be to say that more distant galaxies become visible at a higher wavelength as velocity increases and/or gravity decreases. This seems to be the same thing as saying that spacetime is dilating to include more contents.
Now consider the same logic from the perspective of an object in a black hole. As the object enters the black hole, spacetime contracts rendering the inside of the black hole as vast as the Hubble constant. Light cannot escape because its speed/momentum is fixed relative to the gravity-dilation levels and velocities of objects within the BH. However, an object able to accelerate to increasingly accelerated frames would see spacetime expand to the point that objects outside the black hole would become more accessible.
I can't decide whether these objects then become accessible from the black hole, but if they do it might just be because these objects are already headed for the event horizon and their time relative to that inside the BH is vastly accelerated. So objects outside the BH might be accessible to those inside the BH only because they are themselves entering it at some future moment.
Do you see why I equate the behavior of spacetime inside the Hubble constant as how it would be experienced from inside a BH, considering the relative contraction of space and slowing of time relative to contracted space? In other words, I suspect matter-energy relations to appear the same to an observer within the BH as they appear to the same observer outside the BH when she is outside it.
I also tend to then think that the fact of universal expansion gives each point in the universe its own Hubble constant horizon, which from outside that horizon appears to be the horizon of a black hole. I suppose the correlate of this would be that the outskirts of the Hubble constant as viewed from our velocity/gravity context is indistinguishable from if that edge was completely composed of black holes.
In other words, the ratio of gravity/velocity to C for anything depends on its distance from the observer. Likewise, gravity and velocity are essentially the same thing in that velocity high enough to dilate spacetime in one frame is necessarily pivoting relative to some gravitational fulcrum that corresponds to a gravitational field strong enough to include the object approaching C.
This fulcrum would not have to be a single star or even galaxy. It could be a constellation of galaxies. The point is that in the frame that includes the object approaching C and its gravitational fulcrum, the object is approaching the horizon at which light can no longer escape the fulcrum (hubble constant), which would correspond to the Zwarschild radius from the inside of a black hole.
