yuiop said:
The paradox is now this. All observers should agree on the proper length of the plunger, but in this scenario, frame C sees an increase in the proper length and frame P sees a decrease in the proper length, so we have something that superficially does not agree with relativity. The plunger is either physically compressed or physically stretched but both at the same time is impossible. I know all these sort of paradoxes can be resolved, but the solution seems to be subtle in this case and I wonder if anyone has any suggestions?
I think PeterDonnis has touched on the correct resolution of this sub paradox in that some of the events are spacelike and so are not causally related and the sequence of events is observer dependent. However there are a couple of things I would like to clear up.
For orientation assume the T part of the plunger and the open end of the cylinder to be on the right and likewise the closed end of the cylinder with the button and the face of the plunger that activates the button to be on the right. Also assume that the bomb explodes in both frames and that the transmission of physical compression/expansion forces through the materials is slower than the initial relative velocities of the cylinder and plunger. The observers for a given reference frame are inertial and initially co-moving but do not accelerate after the collisions. Finally assume that the proper lengths of the cylinder and the plunger are such that when they are both at rest relative to each other and the T bar is in contact with the open end of the cylinder that the plunger is too short to activate the button.
Consider the sequence of events as seen in the two different frames.
In the plunger frame (P):
Initially the plunger is at rest and the cylinder is moving with constant velocity to the right. The cylinder is significantly shorter than the plunger.
P1) Button pressed / bomb explodes.
P2) Left end of the plunger compresses due to the collision and the plunger starts to accelerate to the right and starts length contracting. The cylinder slows down and starts to lose length contraction and is also physically stretched at the closed end. Overall the length of plunger decreases relative to the length of the cylinder.
P3) T bar makes contact with the open end of the cylinder.
P4) T bar end of the plunger starts to stretch and the open end of the cylinder starts to compress due to the collision. The T bar end of the plunger starts to accelerate (and length contract) and the open end of the cylinder starts to slow down and lose length contraction.
Finally the cylinder comes to rest and the plunger moves away to the right with constant velocity equal to the initial velocity of the cylinder (assuming the plunger and cylinder have equal rest mass). The plunger is now significantly shorter than the cylinder.
In the cylinder frame (C):
Initially the cylinder is at rest and the plunger is moving with constant velocity to the left. The plunger is significantly shorter than the plunger.
C1) T bar makes contact with the open end of the cylinder.
C2) T bar end of the plunger starts to stretch and the open end of the cylinder starts to compress due to the collision. The T bar end of the plunger starts to slow down and lose length contraction and open end of the cylinder starts to accelerate and length contract. Overall the length of plunger increases relative to the length of the cylinder.
C3) Button pressed / bomb explodes.
C4) The closed end of the cylinder starts to accelerate to the left and the closed end of the cylinder is physically stretched (assuming the middle part of the cylinder has not yet started moving). The left end of the plunger having made contact with the closed end of the cylinder starts to compress.
Finally the plunger comes to rest and the cylinder moves away to the left with constant velocity equal to the initial velocity of the plunger (assuming the plunger and cylinder have equal rest mass). The cylinder is now significantly shorter than the plunger.
Now if we consider all the events to be spacelike separated then the sequence of events in one frame should simply be a time reversal of the events in the other frame but this is not the case. For example the T bar making contact with the open end of the cylinder is the first event in frame C but it not the last event in frame P. Presumably the explanation is that there is a mixture of timelike events (that must retain the same temporal order in any reference frame because they are potentially causally related) and spacelike events that can be any order. C1 and C2 are causally related in frame C, so they retain the same temporal order (P3 then P4) in frame P. On the other hand, the T bar making contact with the cylinder (C1) and the button being depressed (C3) in frame C, are not causally related and happen in the reverse order in frame P (event P3 preceded by event P1) Does that seem about right? If not, would anyone like to clean up and refine the sequence of events described above?
sylas said:
PS. On the answers given previously.
The term "proper length" refers to the length in the frame where the object is at rest. There is no contraction of proper length. Contraction of length from the view of the moving frame goes hand in glove with changes in the notion of what is simultaneous at the front and the back. (yuiop)
I am aware that there is no contraction of proper length due to transformations. I was simply talking about Newtonian change in proper length due to physical forces such as a car being shorter after a cllision in a traffic accident to to permanent deformation of materials when I referred to changes in proper length. I realize there are some ambiguities about the the definition of proper length of an object during a collision when different parts of the same object have different velocities and different states of acceleration at a given instant in an a given inertial reference frame so I have avoided the use of the changes of proper length in this second treatment. I simply use stretch and compress to mean changes in length due physical forces (that may or may not be permanent) in the the Newtonian sense and the term length contraction to refer to changes in measured length due the observers relative velocity in the SR sense.
sylas said:
PeterDonis has the right idea -- except that in the plunger frame, the button was already pressed even before the back end hits the cylinder. The question of deforming the cylinder never arises. You can assume the cylinder does not deform at all.
The question of deformation does arise in the plunger frame, but in this frame it happens after the button is pressed while in the cylinder frame it happens before. Any permanent physical deformation (eg T bar bent and scored by the collision) must happen in all reference frames.
