How Does Mercury Affect the Air Column Length in a Sealed Cylinder?
In summary: Additionally, how it is possible to determine the length of the column when we don't know the area at all?You are asking about Boyle's Law and how to determine the length of a column of gas without knowing the area. Regarding Boyle's Law, it states that the pressure of a gas is inversely proportional to its volume. So, if we want to know the pressure of a gas, we need to know its volume. To do this, we can use the gas law which states that the pressure of a gas is proportional to the amount of gas that is in a particular container. So, if we don't know the area of the container, we can use the gas law to figure out the pressure.
shaiqbashir
106
A vertica cylindrical Tank of length greater rgab 76cm has its top end closed by a tightly fitting frictionless piston of negligible weight. The air inside the cylinder is at an absolute pressure of 1 atm. The piston depressed by pouring mercury on it slowly, so that the temperature of air is maintained constant. What is the length of the air column where the mercury starts to spill over?
Thanks in advance
This has the distinct taste of a homework question and as such should probably have been posted there. Additionally, you'll get a lot more help if you actually ask a question about the problem rather than simply posting the problem. I know I can solve this type of problem; however, simply posting the solution would do you very little good.
So, on that note, how much Hg will there be before it spills over? Hint, you are balancing forces here. The force of Mercury pushing down on the piston vs the force of the compressed gas pushing up on the piston. Think about this force relationship and how it relates to these two fluids. How much downward force is produced by a 74cm column of Hg and how much upward force is produced by compressing 1amt of air from 76cm to 2cm? I think once you balance the forces you'll find your answer.
Good luck.
thanks for ur precious help!
but would u like to tell me that what is the reason for taking 74 cm when it is not given in the question.
Further more! i want u to tell me the right answer only my dear.
im not a cheater, i want to confirm my answer only
Thanks in advance
Thanks in advance
In that case post your answer as well as how you arrived at it. Once you do that, someone may respond...not before.
<moving thread to HH>
Thanks in advance
As Gokul said I'm not going to tell you the answer. I, or many others, can verify your answer though. I chose 74(because the length of the column was 76) to get you thinking along the lines of the Weight of the column of Hg vs the force of the compressed gas pushing back against the Hg.
Hi Guys!
Well thanks a lot for ur help, this problem has now really become an important one for me. Just can't get the correct way to go, now can u remind me how to write the force of a compressing gas with which it is balancing the upward force. Secondly, how it is possible to determine the length of the column when we don't know the area at all?
i have been given the pressure which is 1 atm. now i really cannot understand your logic of 74 cm. Please! i request you to tell me this in detail. furthermore i want to remind you here that in the question it is given that the length of the air column is GREATER than 76 cm so i can't understand ur logic of making 74 cm. Please if u don't want to tell me the correct answer don't tell me then but atleast make the question clarified to me.
Thanks a lot and Good Bye
So when you told us before that you had already solved the problem and only wanted someone to give you the correct answer to verify your answer, exactly what did you mean?
(No one ever said that 74 cm was the correct answer. He was just suggesting that try calculating the forces using that value in order to see what kind of equation you had to set up!)
Let's forget the history (just this once) and start over.
Try Boyle's Law.
1. What is the definition of length of the air column?
The length of the air column refers to the distance between the top and bottom of a column of air, typically measured in meters.
2. How is the length of the air column related to sound?
The length of the air column affects the wavelength of sound waves passing through it. The longer the air column, the longer the wavelength, resulting in a lower pitch. Conversely, a shorter air column will have a shorter wavelength and a higher pitch.
3. What factors affect the length of the air column?
The length of the air column can be affected by temperature, humidity, and air pressure. These factors can change the density of the air, which in turn affects the speed of sound and the wavelength.
4. How is the length of the air column used in musical instruments?
In musical instruments such as wind instruments, the length of the air column can be changed by opening or closing holes or keys. This allows for different wavelengths and therefore different pitches to be produced.
5. What is the significance of the length of the air column in acoustics and sound engineering?
The length of the air column is a crucial factor in understanding and controlling sound waves in acoustics and sound engineering. It is used to calculate the resonant frequencies of a space and the design of acoustic treatments to improve sound quality.
10K
