jrmichler
Mentor
- 2,412
- 3,426
My understanding of the problem. The trailer wheels are not moved. The only change is a 20" extension that moves the hitch point 20" farther from the wheels. The load is not changed between the two cases. The total weight of the trailer does not change, except for a small additional weight from the welded extension.
If my understanding listed and shown above is correct, then @Baluncore's calculation in Post #38 and quoted below, is completely correct. Since the total weight does not change, the weight on the wheels will increase by 148 lbs with the 20" extension.
He calculated the tongue load moment in his first calculation. A moment is a force times a distance. In this case, the force is the tongue load in Case 1 and the distance is the distance from the center of the pin to the center of the axle. When you change the distance from the tongue force to the axle, the moment does not change. In his second calculation he takes the same moment and the longer distance, and finds the new tongue load.Baluncore said:The second part is the unbalanced mass that provides a moment, that rests effectively on the hitch. That moment is 2500 lbs at the old hitch position, 318.5" from the axle-set, which works out at;
318.5" * 2,500 lbs = 796,250 inch⋅pounds
If you extend the trailer axle-set to hitch point length by 20", the length becomes 338.5", so the vertical load on the tractor hitch will become;
796,250 / 338.5 = 2,352 lbs, which is 148 lbs less than the original.
You have the right attitude. Do not give up, we will get you there. A good experiment to show the concept is to clamp a board to a toy wagon, load the wagon with something heavy, then lift one end of the wagon by lifting the board using a spring scale. The farther from the wagon that you lift, the less the force to lift one end.jeredpilot said:I am serious about understanding this. And I am open and willing to be wrong; but I am not willing to misunderstand it.
Good plan. Just be aware of the weight of the extension. If the extension adds 150 lbs weight, the new tongue weight will still be 2500 lbs.jeredpilot said:My plan is to test our answers by using an actual certified truck scale.
