L'Hopital's rule graph problem
The discussion revolves around evaluating the limit of the expression (√(1+tan(x)) - √(1+sin(x))) / x³ as x approaches 0. Participants debate the necessity of L'Hôpital's Rule, with some arguing it should be solvable without it, while others suggest that the limit is indeed 1/4. Various methods are proposed, including algebraic manipulation and substitution, to simplify the expression. There is also a focus on the importance of proving the limit rather than just graphically estimating it. Ultimately, the limit converges to 0.25 as x approaches 0, confirming the solution.
Moose352
Why can't I solve this?
<br /> \lim_{x\rightarrow 0} \frac{\sqrt{1+\tan(x)}-\sqrt{1+\sin(x)}}{x^3}<br />
Mathematics news on Phys.org
What is the problem? (I don't understand your problem statement.) Are you trying to find the limit of that expression as x goes to something?
Yes, I need to evaluate the limit as x->0.
L'Hopital's Rule
Are you familiar with L'Hopital's rule? (Look it up!) It's very useful for evaluating functions with indeterminate form (like 0/0).
No I'm not familiar with L'Hopital's rule. I looked it up in my book (it was listed as L'Hospital's rule :smile: ) but I'm quite sure the problem should be able to be solved without using L'Hopital's rule.
If you graph the equation, it's pretty clear that the limit is infinity.
No, the limit is 1/4.
Why do you say that?
cookiemonster
Well, because L'Hopital's Rule is like 4 chapters away! So assuming that my book hasn't screwed up, I would think they wouldn't put a problem requiring knowledge of L'Hopital's Rule without introducing it first!
Well, what are you "allowed" to use?
cookiemonster
multiply the numerator and denominator by sqrt(1+tanx)+sqrt(1+sinx). Then you should have the factor tanx-sinx in your numerator. Now let t = tan(x/2), then tan(x) = 2t/(1-t^2), sin(x) = 2t/(1+t^2). Plug into the original expression, and note that the limit of tan(x/2)/x as x tends to 0 is 1/2. (This follows from the fact that lim sin(x)/x = 1, which can be proved without L'Hospital's rule.)
I guess my graph is wrong. Perhaps I typed the equation incorrectly. Drat.
Hmm, I think I may have solved it. I'm really tired, so I probably made a lot of mistakes:
=\frac{\tan(x)-\sin(x)}{x^3(\sqrt{1+\tan(x)}+\sqrt{1+\sin(x)})}
=\frac{\frac{\sin(x)}{\cos(x)}-\sin(x)}{x^3(\sqrt{1+\tan(x)}+\sqrt{1+\sin(x)})}
Since the limit of sin(x)/x = 1 as x->0,
=\frac{\frac{1}{\cos(x)}-1}{x^2(\sqrt{1+\tan(x)}+\sqrt{1+\sin(x)})}
=\frac{1-\cos(x)}{x^2\cos(x)(\sqrt{1+\tan(x)}+\sqrt{1+\sin(x)})}
=\frac{\sin(x)^2}{x^2\cos(x)(\sqrt{1+\tan(x)}+\sqrt{1+\sin(x)})(1+\cos(x))}
=\frac{1}{\cos(x)(\sqrt{1+\tan(x)}+\sqrt{1+\sin(x)})(1+\cos(x))}
=\frac{1}{1(\sqrt{1+0}+\sqrt{1+0})(1+1)}=\frac{1}{4}
Does this work? Wong, I haven't checked out your solution yet.
=\frac{\sin(x)^2}{x^2\cos(x)(\sqrt{1+\tan(x)}+\sqr t{1+\sin(x)})(1+\cos(x))}
How do you do this step? The first has cos(x), not cos2(x).
It does reduce to lim_{x-&gt;0}\frac{1- cos(x)}{x^2} since the rest has a limit of the rest is 1/2. I would do that either by L'Hopital's rule or by replacing cos(x) by by its McLaurin series. Either way the whole limit is 1/4.
Not sure what your question is Halls, but if you're asking how I got from 1-cos(x) to 1-cos(x)^2, i multiplied numerator and denominator by 1+cos(x). What
You can evaluate the limit as it is just using a table or a graph. Once I typed in the equation properly, the value of f(x) approached 0.25 as x approached 0, from both sides. Why bother doing all this? Were you asked to prove that the limit is 0.25?
Because THIS IS MATH, not a drawing , guessing game.
To Moose353: Sorry, I didn't see the 1+ cos(x) in the denominator. I see nothing wrong with your solution.
To Loseyourname: Hello3719's point is that drawing a graph and observing that it APPEARS to converge to 1/4 doesn't prove that it does (as opposed to converging to 0.2500000000000000000000000000001, say).
No problem Halls. Thanks for the help!
I know. That's why I asked if he simply needed to get an answer or if he needed to prove an answer. If no proof is needed, a shortcut never hurts.
