Lie Algebras: [H1, H2] = 0 => h1h2 = h2h1
  • Thread starter Thread starter Sajet
    Lie algebras
Sajet
Hi! I have the following problem:
Let G be a connected Lie Group, \mathfrak g its Lie algebra. Let \mathfrak h_1, \mathfrak h_2 \subset \mathfrak g be subalgebras of \mathfrak g with [\mathfrak h_1, \mathfrak h_2] = 0, H_1, H_2 the subgroups belonging to them. Show: h_1h_2 = h_2h_1 for all h_1 \in H_1, h_2 \in H_2.
I tried to solve this by using the adjoint represantation and although it looks very promising, I can't really get it to work.
If I define C_x(y) := xyx^{-1} as the conjugation, then what needs to be shown is: C_{h_1}h_2 = h_2.
I'm using these symbols: Ad: G \rightarrow GL(\mathfrak g), Ad(g) := C_{g*e} and ad_X Y = [X, Y].
My idea is as follows: [\mathfrak h_1, \mathfrak h_2] = 0 implies ad_{h_1}ad_{h_2}=ad_{h_2}ad_{h_1} \Rightarrow Ad_{*e}(h_1)Ad_{*e}(h_2) = Ad_{*e}(h_2)Ad_{*e}(h_1) \Rightarrow (Ad(h_1)Ad(h_2))_{*e} = (Ad(h_2)Ad(h_1))_{*e}
\Rightarrow (Ad(h_1h_2))_{*e} = (Ad(h_2h_1))_{*e}. Since G is connected this implies Ad(h_1h_2) = Ad(h_2h_1) \Rightarrow C_{h_1h_2*e} = C_{h_2h_1*e} \Rightarrow C_{h_1h_2}= C_{h_2h_1} \Leftrightarrow C_{h_1} = C_{h_2h_1h_2^{-1}} but I'm not getting any further from here.
Maybe this is the wrong path altogether but I don't see how else I could use the connectedness of G as well as the information on the Lie bracket to make a statement on the group elements themselves.
How do you define the Lie subgroup associated the Lie subalgebra h1? I'm going to guess that you want to use the exponential map here.
"If \mathfrak h \subset \mathfrak g is a Lie subalgebra, there exists a unique connected Lie subgroup H \subset G with Lie algebra \mathfrak h."
I'm sure this unique connected subgroup is meant in the assignment.
I'm sure it is too. Look at how they proved that statement. I'm guessing you can use exp(A)exp(B)=exp(B)exp(A) if [A,B]=0.
Hi! Thank you for your response.
The proof for this theorem uses distributions and leafs. But it is also shown that exp(A)exp(B) = exp(B)exp(A) if [A, B] = 0 at a different point in our script. But are you sure this fact can be used here? Is the exponential map necessarily surjective on a connected Lie group?
I'm a little confused. I tried to look this up and while I found two sources stating
"If G is a Lie group and G0 is the connected component of 1, then G0 is generated by exp(g)."
which would apply to a connected Lie group (right?), I found other sources stating:
"Not even on connected Lie groups is the exponential map necessarily surjective. Example: SL(2,IR)."
And if it's not surjective, how I could I use your idea if h_1 or h_2 are not included in the image of exp?
edit: Ok, I think I get it now. The first statement is just about a generator of the Lie group. I'll take a closer look at it now.
edit 2: Thank you, I think this works!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
