What is the angle of attack for a Rogallo wing and how does it generate lift?
  • Thread starter Thread starter Frenemy90210
    Lift
A Rogallo wing does generate lift, primarily through the angle of attack, which is adjusted via the bridle. The angle of attack is defined as the angle between the wing's chord line and the oncoming airflow. Despite its unique design, the wing can still produce lift by manipulating this angle. All wings, including the Rogallo, require a proper angle of attack to function effectively. Understanding this principle is crucial for optimizing the performance of Rogallo wings.
Frenemy90210
Does a Rogallo wing generate a lift at all ? If yes, how ? It does not seem to have wing profile to generate lift.
The wing is operated with an angle of attack provided by the adjustment of the bridle. All wings require an angle of attack to provide lift. Angle of attack is the angle between the chord and the incoming air stream.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
