rcgldr said:
Part of whether or not Bernoulli is violated depends on the frame of reference. If using the air as a frame of reference, and noting what occurs as a wing passes through a volume of air, a wing performs work on the air, resulting in a non-zero velocity of the air (mostly downwards, somewhat forwards), at the moment the affected air's pressure returns to ambient. If using the wing as a frame of reference, in the case of an idealized wing, the oncoming flow is diverted with no change in speed. For a real wing, some energy is lost in the process.
That flow diversion happens regardless of which frame of reference you use to view the problem. The thing is, in either case, the losses to lead to this effect occur due to viscosity and are confined to the boundary layer, so Bernoulli's equation still holds out in the free stream. After all, Bernoulli's equation can certainly be used in the presence of an external body force so long as that force is irrotational (conservative), and without considering viscosity, all of the forces acting here are conservative. You wouldn't ever use Bernoulli's equation in the boundary layer anyway.
Bernoulli's equation can be derived directly from the equations of motion using only the assumptions of irrotationality (which implies inviscid), incompressibility, and steady flow. You can generalize it to unsteady flows, although the conditions of validity change (cf.
Karamcheti).
rcgldr said:
For a basic description of lift, my issue with Bernoulli is that it doesn't deal with the relationship between neighboring streamlines, such as the effects related to streamline curvature.
I still do not understand what yo mean here. There is no issue of the relationship between neighboring streamlines. Streamlines do not affect the flow; they are a concept that can be calculated to help visualize and understand the flow field after the flow field has been calculated (or measured). No one draws the streamlines and then uses that to deduce the flow field. You can sometimes substitute the streamfunction into the governing equations and calculate the flow field that way, but you are still calculating the whole field and can place a streamline at any arbitrary location and back the whole-field velocity out of the solution. Streamline curvature only means that there is something diverting the flow in some fashion, which we already know just by defining the problem. There is nothing more to it than that.
rcgldr said:
The Newton explanation is macroscopic, only looking at the overall effects of diverted flow: lift is related to the net average downwards acceleration of affected air, drag is related to the net average forward acceleration of air, so it might serve as an explanation, but it's not very useful as a basis for a mathematical model of an airfoil.
True, it is essentially useless for trying to calculate the lift on some arbitrary airfoil shape. There is no method for this invoking Bernoulli's equation that is not harder to implement than at least one alternative method that could be used in the same situation. That doesn't change the fact that the particular view of the phenomenon is physically correct, though.
rcgldr said:
Neither Bernoulli or Newton explain why air flow would tend to remain attached to the upper surface of a flat or convex surface (with a reasonable angle of attack).
It would tend to remain attached because nature abhors a vacuum. If the air flow (or water flow in the case of a hydrofoil) did not remain somehow attached to the surface, there would be a vacumm bubble in its place, a massive pressure gradient pushing the fluid back toward the surface, and therefore the fluid would tend to be attracted back toward the surface anyway. In the case of a separated airfoil, there is still air by the surface, only it is slower and circulating as a result of the pressure gradient along the surface. That, of course, causes stall in many cases.
Of course, that doesn't answer the question that many people
really have. Why
does the fluid move faster over the top of the airfoil (or equivalently, why does a net circulation develop around an airfoil)? It all comes back to viscosity. If you put an airfoil shape into an ideal, inviscid fluid, then you would have zero lift, as the leading stagnation point and trailing stagnation point would set up in locations that allow the air before and after the shape to remain undisturbed. Generally, this means the trailing edge stagnation point ends up somewhere above the airfoil for a positive angle of attack. You would also measure no drag, a phenomenon known as D'Alembert's paradox. Of course we know this isn't what happens in a real fluid, and the difference is viscosity and boundary-layer separation.
According to potential flow theory, the trailing edge of the airfoil is a singularity point, so in order for the flow field with zero lift predicted by potential flow to occur, there would need to be an infinite velocity around the trailing edge. Clearly that can't happen in real life. Instead, that sharp trailing edge (or any sufficiently abrupt truncation to the end of the airfoil) causes the boundary layer to separate at that point. Essentially, with viscosity and a sufficiently abrupt trailing edge, we are choosing our own rear stagnation point. This is the reason why modeling lift using a panel method, which uses potential flow, requires the use of the artificial Kutta condition. Now with this "artificial" trailing edge stagnation point combined with the requirements for conservation of mass and momentum ensure that the flow velocity over the upper surface is faster in order to enforce that rear stagnation location. This is true whether it is viscosity enforcing the trailing edge stagnation point or the Kutta condition.
Once you have that flow field, you can use Bernoulli's equation if you wish to calculate lift. Calculating drag is much,
much more difficult and, in general, can't even be done accurately by modern computer codes.
