Lifters: How the Biefeld-Brown Effect Works
  • Thread starter Thread starter username
    Work
The discussion centers on the Biefeld-Brown effect and its role in lifters, with participants debating the primary source of lift. While ionic wind is acknowledged as a significant contributor, some argue there may be additional mechanisms at play, as evidenced by experiments showing minimal lift loss with barriers like cardboard. The practicality of using high-voltage power supplies, such as those above 50KV, is questioned, with participants expressing interest in further experimentation. There is a call for calculations to assess thrust variations in different atmospheric conditions to clarify the role of ionized air. Overall, the conversation highlights ongoing inquiries into the physics behind lifters and the need for more empirical testing.
username
Lifters use the Biefeld-Brown effect see:
http://jnaudin.free.fr/lifters/main.htm
I understand that some of the lift is created by ionic wind but there must be another component as there is a video in which a piece of cardboard is placed in-between the anode and cathode with no noticable loss in lift.
Hey username,
I looked at this before but not really that closely. I assumed this was a simple HV repulsion device [having made so many myself]. It appears to me that ionic wind is the only means of lift. I didn't see the video with the cardboard - can you tell me which one it is - but I would think at 30KV this is no problem. I will have to view the configuration to be sure.
Well can't find the original video but this url contains similar experiments http://jlnlabs.imars.com/lifters/inthebox/
I am still in the 'Electric Charge,Forces and Fields' section in my physics book, so take everything I say with a grain of salt. Have you ever made a lifter with a >= 50KV power supply, is there any reason why this would not be practical?
EDIT: Contrary to his claims, I do not think this experiment disproves ionic wind as the primary thrust. However I think these experiments do.
http://jlnlabs.imars.com/lifters/rototube/index.htm
http://jnaudin.free.fr/html/ttbekp.htm
I don't get all this crap about lifters not using ionized air. If they want to prove it all they have to do is calculate the thrust drop (if any, I'm assuming there will be) when the entire atmosphere is rarified. I have on many occaisons thought of doing this and someday I may actually get around to it :-)
I know it is annoying, I unfortunatly don't have the space (or money atm) to do any tests. Post your results here if you ever get around to doing some ;)
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
