keepitmoving
- 97
- 0
if an object moving at .99 c emits a light, does that light move away from the emitter at 1.00 c ?
No it won't. A stationary observer would still measure the speed of light as c. The invariance of the speed of light is a fundamental concept in special relativity.keepitmoving said:if the emitter suddenly stops, does the light know it? If the light doesn`t know it, the light will be moving at c plus the previous speed of the emitter.
In a way it will, but with a different definition of "plus". In SR you have to add up velocities like this:keepitmoving said:the light will be moving at c plus the previous speed of the emitter.
pesto said:Fredrik, what equation is that? Does it have a name I can google? :)
pesto said:Does the [tex]u \oplus v[/tex] means the velocity of the emitter relative to the observer plus the velocity of the photon relative to the emitter? If I could try your patience for one more stupid question, what's a plus sign with a circle around it? Just a sign for adding vectors or what?
Thanks again.
malawi_glenn said:v is the velocity relative the observer for objectA and u is the velocity relative the observer for objectB, always. And [itex] u \oplus v[/itex] means the relative velocity of A and B as measured by the observer. [itex] \oplus [/itex] means "composition law for velocities under boosts"
In the wiki article this [itex] u \oplus v[/itex] is just called "s".
[tex] <br /> here is really good explanation what is included <a href="http://math.ucr.edu/home/baez/physics/Relativity/SR/velocity.html" target="_blank" class="link link--external" rel="nofollow ugc noopener">http://math.ucr.edu/home/baez/physics/Relativity/SR/velocity.html</a><br /> <br /> forget about my last post, I was not focused on this thread, Sorry for that.<br /> <br /> I have changed it now so it should be correct now, I had many irons in the oven :-) (and maybe I was confused by the non-standard notation \oplus ) ;-)<br /> <br /> The point of the calculation given by Fredrik is that light always move with speed c for all observers.[/tex]pesto said:Woah! Back to the old drawing board. Thank you for the explanation. I though [tex]u \oplus v[/text] or "s" was the velocity of objectB relative to the observer![/tex]
Sorry, that's confused.malawi_glenn said:v is the velocity relative the observer for objectA and u is the velocity relative the observer for objectB, always. And [itex] u \oplus v[/itex] means the relative velocity of A and B as measured by the observer. [itex] \oplus [/itex] means "composition law for velocities under boosts"
DrGreg said:Sorry, that's confused.
If A, B and C are 3 objects all moving along the same straight lineThe symbol [itex]\oplus[/itex] is not standard notation. Some may use it but others don't. It's just a way of denoting a different way of "adding" velocities. I'd prefer to call it "composition" rather than "addition".
- u is the velocity of B measured by A
- v is the velocity of C measured by B
- [itex]u \oplus v[/itex] is the velocity of C measured by A
Sorry, my intentions weren't clear. That comment was really aimed at Pesto in answer to post #11.malawi_glenn said:yup I know, it was an error, I fixed it.
regarding "composition" vs. "addition" I actually mentioned that [itex] \oplus[/itex] stands for "composition" right? why adding that?
Cheers
DrGreg said:Sorry, my intentions weren't clear. That comment was really aimed at Pesto in answer to post #11.
In case anyone reading this thread is confused, I was correcting an error in post #12, but then malawi_glenn corrected his own error at the same time, making my comment out of date by the time I posted it. But it's too late to undo that now without causing even further confusion...![]()
