Examining Fermats Principle & Light's Path of Min Time
Light follows a path of minimum time due to Fermat's principle, which states that this path leads to constructive interference among neighboring paths, while other paths result in destructive interference. When light transitions between media, some light is reflected and some refracted, as not all light can pass through without reflection. The amount of light reflected is determined by the boundary conditions of electromagnetic fields, which can be analyzed using Fresnel equations. These equations help explain the relationship between the refractive indices of the materials and the resulting light behavior. Understanding these principles is essential for comprehending the nature of light's interaction with different media.
ajayguhan
Why does light follows a path of minimum time?
I.e., is there any theory or explanation behind the fermats principle?
Science news on Phys.org
Yes, that's the path that leads to constructive interference between neighbor paths. all other paths lead to destructive interference between neighbor paths.
Why does another path leads to destructive interference? And when light passes from one medium to another, a part of light reflected and the remaining is just reflected.
Why it so? I mean can't the entire light just pass from one medium to another complete by bending at an angle (i.e., refraction) without any portion being reflected?
And why does reflection takes place?
For the path of minimum time (because it is a extremum) all neighbor paths take the same amount of time (to first order - zero derivative of time taken with respect to path - that's the definition of extremum). That means that they all have the same phase and interfere constructively. That's not the case for other paths which end up interfering destructively.
To understand why a specific amount of light gets reflected, you need to understand the boundary conditions for the electromagnetic fields. That's a fairly complicated topic. Look up Fresnel equations.
When light goes from one medium to another, there are two paths which lead to constructive interference - one which goes into the other medium, and the other is being reflected. To calculate how much is reflected, you need to know the refractive index of the materials. here is more detail: http://en.wikipedia.org/wiki/Fresnel_equations
edit: haha, dauto beat me to it :)
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
