Limit at infinity, no vert asymptote, why?
jrjack
Find the vertical asymptote(n) and evaluate the limit as x \rightarrow n^-, x\rightarrow n^+, or state Does Not Exist.
\frac{\sqrt{4x^2+2x+10}-4}{x-1}
I have taken the limits at \pm\infty=2,-2 and understand those are my horizontal asymptotes.
I have also finished the problem and got the correct answer (DNE), but I cannot mathematically understand why it does not have a vertical asymptote, I figured this out by graphing.
Based on similar problems, I (wrongly) assumed setting the denominator equal to 0 gives the Vert Asymptote. This was the case in the 3 problems before this one, but that was after factoring and reducing the equations. After trying to find the limit of this equation as x\rightarrow1...I gave up, and graphed it.
I don't feel this is the correct approach. What is a better approach? Can I find that this problem has no vertical asymptote without graphing?
...After typing this I think my answer lies in the definition of a vertical asymptote, and since the limit of f(x) as x->1 was not \pm\infty, then there is no vert. asymptote.
Is that correct?
Sure, it's not a vertical asymptote because the limit as x->1 is not infinity. To work this out algebraically multiply the numerator and denominator by sqrt(4x^2+2x+10)+4 and factor. It's the usual 'conjugate' thing you should think about when you see a square root.
Thanks, I always seem to forget the simple things.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
