Limit in Two Variables: Approaching the 0/0 Case
  • Thread starter Thread starter tysonk
    Limit Variables
tysonk
How do I approach such question,
0/0 case in two variables, I can't find a simplification.
Thanks for the help.
Look for two ways to approach (0,0) that will give you different limits. That will prove the limit doesn't exist and you don't have to worry about it anymore.
isn't it -1?
edit: oh got it
2nd edit: nope still got -1
I approached from both possible y's
veneficus5 said:
isn't it -1?
edit: oh got it
Look at the limit as y->0 when x=0 and the limit as x->0 when y=0.
I learned that one can plug in things like y=x, y=2x to help determine whether a limit can exist. If a different value is obtained then a limit may not exist.
Is it still possible to plug in y=x^3
Because when we plug in y=x and y=x^3 we get different values. Thanks.
Sure. That works. I still think x=0 and y=0 are easier, but it's your choice.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
