Limit of function with 3 variables
halcyone
Evaluate the following limit as (x,y,z) --> (0,0,0), if it exists:
f(x,y,z)=xyz/x^3+y^3+z^3
2. Other relevant equations
I already know that f(x,y)=xy/x^3+y^3 doesn't exist, from a previous exercise. Hence, I suspect that this limit does not exist.
I've taken the limit as we go along the x-axis, y=0, z=0, x-->0:
lim (x)-->0 0/x^3 = 0.
But, from the equation, you can tell that if you let any of x, y or z=0, you will get the limit to be equal to 0. I'm out of ideas on ways to approach this. I've tried letting y=x, but I can't cancel x or z out from the equation to make the limit not equal to 0.
I would appreciate any hints! Thanks.
Ok, it approaches zero along the x axis. Try approaching 0 from a different direction. Say, set x=y=z=a and let a->0.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
