Limit of Logarithmic Function as n Goes to Infinity
  • Thread starter Thread starter EV33
    Limit
The discussion revolves around finding the limit of the function log(n)/sqrt(n) as n approaches infinity. Participants are exploring methods to prove that this limit is zero without relying on specific theorems or techniques they have not yet learned.
  • Participants discuss the use of L'Hôpital's rule and whether it is applicable, with some expressing uncertainty about its relevance. Others suggest alternative methods, such as exponentiating the sequence or using a ratio test, to analyze the limit. There is also mention of bounding the sequence by geometric sequences.
The discussion is active, with various approaches being proposed. Some participants are questioning the appropriateness of certain methods based on their current knowledge. There is no explicit consensus on a single approach, but several lines of reasoning are being explored.
Participants note that they have not yet learned L'Hôpital's rule and are focused on proving the limit rather than evaluating it directly. There are references to specific techniques and theorems that may not be familiar to all participants, indicating a range of knowledge levels within the group.
EV33
Does anyone have any idea how to take the limit of log(n)/sqrt(n) as n goes to infinity?
I know it is zero by my good old calculator but I am not aware of any theorems that I could use to solve this. If anyone could give me a hint on how to start that would be very helpful.
Thank you.
Thank you.
Have you learned about L'Hopital's rules for finding limits of indeterminate forms? (in this case, infty/infty)
L'hospitals ?!
╔(σ_σ)╝ said:
L'hospitals ?!
It used to be l'Hospital. French spelling has changed. Probably ought have the circumflex over the o though.
No we haven't learned that. We are trying to prove that this limit is zero not evaluate it!
I guess you could exponentiate your sequence, show that it goes to one, then take the log at the end.
If you've proved the limit is zero, then you have evaluated it. If you haven't done l'Hopital yet then try malicx idea of looking at lim log(e^n)/sqrt(e^n). Apply a 'ratio test'. Show it's bounded by a geometric sequence r^n with r<1.
Thank you Dick. But are you basically doing substitution there because evaluating that limit with some random e^x in there doesn't make sense with anything we have done in our course so far.
If lim f(n) as n->infinity has a limit, then that limit is the same as the limit of f(e^n) as n->infinity. Because as n->infinity, e^n also goes to infinity.
Well... lim log(n)/sqrt(n) = lim log(e^n)/sqrt(e^n), since in either case, e^n and n both go to infinity (one just does it faster!)
There are a lot of sequence theorems involved with sequences, functions, and combinations of both but I don't know which you have learned or are expected to know.
So, given that, can you squeeze your sequence between another couple sequences that have the same limit?
Maybe you can something about the limit of the function:
[tex] x \, \ln{x}[/tex]
when [itex]x \rightarrow 0[/itex].
  • · Replies 20 ·
  • · Replies 24 ·
  • · Replies 23 ·
