Limit of Series: Find Out How (N+1)/(2N+1) = 1/2
  • Thread starter Thread starter magnifik
    Limit Series
magnifik
can someone please explain to me how the limit of (N+1)/(2N+1) as N goes to infinity is equal to 1/2? i know this is really simple, but I'm pretty rusty on this stuff.
If you substitute N=\infty you will get undetermined form \frac{\infty}{\infty}. So you can L' Hospital rule, i.e, differentiate numerator and denominator (individually) with respect to N and then take limit for the resulting expression.
When both the top and bottom go to infinity you can look at the coefficients in front of the variable.
When you have a rational function of N, you can divide the numerator and denominator by the highest power of N. In your case:
<br /> \lim_{N \to \infty} \frac{N+1}{2N+1} =\lim_{N \to \infty} \frac{(1/N)(N+1)}{(1/N)(2N+1)} = \lim_{N \to \infty} \frac{1+1/N}{2 + 1/N} = \frac{1 +0}{2 +0} = \frac{1}{2}<br />
since \lim_{N\to \infty} 1/N = 0.
It's probably easier to just stick in limits and cancel out the irrelevant details to leave just the numerator and denominator as 1 and 2, slightly shorter process if less robust ie n+1/n+1 in both the numerator and denominator =1 with appropriate limits. That was the way I was taught but the answer above is completely correct. It's intuitively correct to if you can imagine them both converging in an iterative way ie for every value of n the answer is converging to 1/2 in an infinite series.
Sorry nice to see a new way of doing something that is more rigid just pop corn posting in case it gets even more interesting.
thank you all
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
