Limits of multiple variables along y=mx
The discussion revolves around solving a limit problem involving the function f(x,y) = (x^3y)/(2x^6+y^2) as (x,y) approaches (0,0) along different paths. The user initially substitutes y=mx and simplifies the expression, leading to a limit of mx^2/(2x^4+m^2). After receiving guidance, they successfully solve the first two parts of the assignment but struggle with a third part that requires showing the limit along y=x^3 does not exist. The conversation highlights the importance of path dependence in limits, as different approaches yield different results, indicating the overall limit does not exist. The user expresses gratitude for the assistance, noting the complexity of the problem.
Beamsbox
This is an assignment problem I have. Can't seem to figure it out. It has two parts, one to prove that the function approaches 0 where y=mx and and one where the function approaches 0 from y=kx2...
f(x,y) = (x3y)/(2x6+y2)
I've attempted both parts and get stuck on what seems like the same issue. Basically I've substituted y=mx for y. Giving:
Please assume that lim (x,mx)→(0,0) is at the beginning of these workings.
lim f(x,mx) = x3(mx)/(2x6+(mx)2)
lim f(x,mx) = mx4/[(x2(2x4+m2)]
lim f(x,mx) = mx2/(2x4+m2)
I suppose I could try L'Hopital at this point, but it doesn't seem to help I think the 3rd derivative leaves you with 0/0.
Could I get some direction, please?
Thanks prior!
Thanks prior!
You have y = mx, so that if x→0, then mx→0 . This changes taking the limit as (x,y)→(0,0) to taking the limit as x→0.
For your problem:
If y = mx, then lim (x,y)→(0,0) f(x,y)
becomes, lim x→0 f(x,mx), where \displaystyle f(x,\,mx)=\frac{x^3(mx)}{2x^6+(mx)^2}=\frac{mx^4}{x^2(2x^4+m^2)}
Thanks for your quick reply. That definitely helped me understand. I was able to answer both parts of the question with your help. The third part says to show that lim along y=x3 does not exist.
Now, I figured it to be 1/3, but I think the book is implying that the limit does not exist because the first two paths worked, but the third was different, therefore the limit does not exist. Would you agree?
Thanks again for your help! I spent way too much time dinkin' around with that problem...
That's the idea.
why use L'Hopital? the limit you show is not of type 0/0 as x->0
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 26 ·
