Line detection/electronics help
  • Thread starter Thread starter compton_effect
    Line
The discussion focuses on a project involving line detection for a sumo bot using QRD1114 photo emitters and detectors. The main issue is that the transistor output voltage levels (2.4V low and 4.6V high) are insufficient for LS family digital logic. A suggestion was made to use an LM741 op-amp with low gain to offset the low voltage and amplify the high voltage to 5V. Additionally, using a single-supply comparator with a reference voltage set between the sensor's output levels and incorporating hysteresis in the feedback path was recommended as a better approach. The conversation emphasizes the importance of ensuring the output meets the logic level requirements for effective line detection.
compton_effect
I'm in an electronics class in which we build a sumo bot for our final project. Right now I'm working on the line detection using QRD1114 photo emitters/detectors. The problem is that the transistor is outputting about 2.4 volts (low) and 4.6 volts (high) on a 5 volt input, which is borderline for inputting into the LS family digital logic.
I received a suggestion that I should use an LM741 op-amp with a low gain (~10) and tie 2.4 volts to the offset, so it nulls the low input and amplifies the high to the 5V rail. On the 741, there are two offset nulls, though I'm not exactly sure how to null out a 2.4 volt signal. Can anyone give any suggestions as to how to achieve this or possibly a better way to approach this problem? Thanks.
What supply rails do you have available? Probably the best way to process the output of the photo sensor would be to use a single-supply comparator, with its reference set between the high and low output voltages of the sensor. Be sure to include some hysteresis in the + feedback path of the comparator.
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
