B Line Equations: Rearranging Ax + By + C = 0 to y=mx+b
  • B
  • Thread starter Thread starter Einstein's Cat
    Line
The discussion focuses on rearranging the general line equation Ax + By + C = 0 into the slope-intercept form y = mx + b. Participants confirm that this rearrangement is possible by isolating y, resulting in y = (-A/B)x + (-C/B), provided that B is not zero. It is noted that vertical lines, such as x = 2, cannot be expressed in slope-intercept form due to their undefined slope. The conversation emphasizes that all allowed operations can be performed on equations to achieve the desired format, except in cases where B equals zero. Overall, the rearrangement is valid for non-vertical lines.
Einstein's Cat
Say a line equation is expressed with the General equation of Ax + By + C = 0; can one just simply rearrage this into the form of y= mx + b?
Mathematics news on Phys.org
What ways of rearranging Ax + By + C = 0 into the form y= mx + b have you tried ?
I just made y the subject so that
Y= (-a/-b)x + (-c/-b); this may not be correct, I've just done it now
You can simplify the expression.
It doesn't work if b=0.
You can always perform all allowed operations on equations.
Vertical lines such as x = 2 are special cases of the general equation (A = 1, B = 0, C = -2), but can't be written in the slope-intercept form, since the slope is undefined. Any other line that isn't vertical can be written in either equation form.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
