Linear Algebra- Kernel and images of a matrix
The discussion focuses on the relationships between the kernel and image of a matrix A and its powers. It establishes that if A is invertible, then ker(A) and im(A) are trivial and span the entire space, respectively. For non-invertible matrices, it is concluded that ker(A) is a subset of ker(A^2), and similarly, im(A) contains im(A^2). The conversation emphasizes that while these sets are not necessarily equal, they exhibit a hierarchical structure as powers increase. Overall, the relationships between the kernels and images of matrix powers reveal important properties in linear algebra.
KyleS4562
Consider a square matrix A:
a. What is the relationship between ker(A) and ker(A^2)? Are they necessarily equal? Is one of them necessarily contained in the other? More generally, What can you say about ker(A), ker(A^2), ker(A^3), ker(A^4),...?
b. What can you say about im(A), im(A^2), im(A^3), im(A^4),...?
2. The attempt at a solution
So i believe if A is invertible nxn matrix, than ker(A)={<0,0,0>} and so will ker(A^2) and so on. And the image of A if A is invertible is im(A)=R^n and so will the im(A^2) and so on, but I am not sure what it would be for other conditions of A at least that's what I think this question wants.
a. If x \in \ker(A), what can you say about A^2 x? What does that tell you about \ker(A^2)?
b. For any x, A^2x is in \operatorname{im}(A^2). If you rewrite A^2x as A(Ax)=Ay, what can you say about \operatorname{im}(A)?
for A: A^2 * x would equal the zero vector which means the ker(A^2) contains x but is not necessarily equal because it may contain another vector
B. Is that saying the im(A) contains the im(A^2) but is not necessarily equal to the im(A^2) because it will span more vectors?
In other words, we have \ker(A)\subset \ker(A^2).
Yes. You could also write : \operatorname{im}(A^2)\subset \operatorname{im}(A)
Now, how can you apply this to \ker(A^3), \ker(A^4)... and \operatorname{im}(A^3), \operatorname{im}(A^4)...?
alright, thank you very much for your help
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 41 ·
  • · Replies 26 ·
