Linear Algebra: Proving Linear Dependence in Subspaces with Basis Intersection
In the discussion, participants analyze the linear dependence of the union of two bases, Bu and Bw, from five-dimensional subspaces U and W of a nine-dimensional vector space V. The main argument is that if Bu and Bw are disjoint, their union cannot be linearly independent due to the dimension constraints of V. Clarifications are made regarding the definitions of basis and span, emphasizing that the union of two bases with no intersection cannot exceed the dimension of V. The confusion arises around the implications of linear independence and dependence when combining these bases. The thread concludes with a request for further assistance in understanding these concepts.
akima
Let V be a 9 dimensional vector space and let U and W
be five dimensional subspaces of V with the bases Bu
and Bw respectively,
(a) show that if Bu intersect Bw is empty then
Bu union Bw is linearly dependen
(b)use part (a) to prove U intersect W is not
equal to the 0 vector
now i have already done part (a), now i have already
done part (a). can you please help me..
for part a.. this is what i have briefly...
we know Bu intersect Bw has nothing in common.
Since Bu and Bw is a basis we know that it is linearly independent.
Therefore Let bu be a linearly independent
subset of a vector space V and let Bw be a
vector in V that is not in Bu, then Bu union Bw
is linearly dependent iff Bw is in the span of Bu... (by a theorem)
by definition of a basis we know, span ( Bu) = v
therefore, the question now is if Bw is in V
which is true ( definition of a basis)... therefore
Bu union Bw is linearly dependent if Bu intersect Bw is nothing...
my homework is due tomorrow... if some one can help me before then or even give me a clue.. it will be appreciated... :)
Your argument is severely confused.
Here you have just defined B_U for the second time, which won't fly. Either B_U is a basis for U, or B_U is an arbitrarily chosen linearly independent subset of V. The first is what the problem says.
akima said:
then Bu union Bw
No. For a single vector w, B_U \cup \{w\} is linearly dependent if and only if w \in \mathop{\mathrm{span}} B_U. It is false that B_U \cup B_W is linearly dependent iff B_W \subset \mathop{\mathrm{span}} B_U, because B_W has more than one vector in it (try to construct some simple examples in \mathbb{R}^3 with B_U and B_W having two elements each).
No. B_U is a basis for U, not V; \mathop{\mathrm{span}} B_U = U.
It seems like you are thinking much too hard. The dimension of V is 9. If B_U and B_W are disjoint, what is the size of the set B_U \cup B_W? Can this set be linearly independent?
sorry about the late reply... I am kinda new to physics forum...
I am actually completely lost with this problem... well i would guess the Bu U Bw is linearly independent.. right? because any basis by definition is linearly independent... so wouldn't their union be independent as well? i don't know.. um just confused abou this problem..
if you could help me out that would be really great :)
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
