Linear equations using addition
uperkurk
I'm probably making a silly mistake or Wolfram Alpha is lying to me.
Question: Find the value of c and d.
3d=13-2c
\frac{3c+d}{2}=8
Rearranged, simplified and multiply each equation by 2:
6d+4c=26
d+3c=16
Now find the common multiple which in my case I will use 12:
18d+12c=78
-4d-12c=-64
Then add them and find what d is worth:
14d=14
d=1
Now when I plug this back into the equation, I will use the first one:
3(1)+2c=13
3+2(c)=13
c=5
d=1, c=5
What am I doing wrong? Sorry if this is the long winded way to do it.
Mathematics news on Phys.org
Your answer is correct, as you can verify by plugging ##d = 1## and ##c = 5## into the two given equations.
So Wolfram is lying to me it seems?
Wolfram says the answer is c=\frac{35}{16}, d=\frac{23}{8}
It seems more likely that you didn't enter the problem correctly into Wolfram Alpha.
I think you told Wolfram the second equation was
$$3c + \frac d 2 = 8$$
Yes, looking back that is what is shows under "Input Result" How would I input the correct format?
If you meant this:
$$ \frac{3c + d}{2}$$
you should have written it as (3c + d)/2.
Also, there was some wasted effort when you multiplied the first equation by 2. You didn't need to do that.
Use correct brackets.
