nysnacc
- 184
- 3
I set up the Wronskian?? and compare them?
You could evaluate the Wronskian of the three functions, or you could use the definition of linear independence.nysnacc said:Homework Statement
A linear independent check is a mathematical process used to determine if a set of vectors in a vector space are linearly independent.
Performing a linear independent check is important because it helps us understand if a set of vectors can be used as a basis to span the entire vector space. It also helps us determine if there are any redundant vectors in the set.
There are several methods that can be used to perform a linear independent check. These include the determinant method, the reduced row echelon form method, and the rank method.
Yes, a set of vectors can be linearly independent in one vector space but not in another. This is because the dimension of the vector space can affect the linear independence of the vectors.
A linear independent check has various applications in fields such as computer graphics, engineering, and physics. It is used to determine the dimension of a vector space, solve systems of linear equations, and find the basis for a vector space.
