Solving Linear Inequalities on a TI-83 Calculator
Graphing linear inequalities on a TI-83 calculator is not straightforward, as the calculator does not support direct input of inequalities. Users can graph the corresponding equations, such as 2x + 2y = 4, to identify boundary lines. The feasible region is determined by the intersection of all inequalities, which can be plotted manually for clarity. The minimum and maximum values of the objective function P=30x + 10y will occur at the vertices of this region. For complex problems, manual graphing is often recommended for better understanding and accuracy.
Corkery
Mnimize and maximize:
P=30x + 10y
Subject to 2x + 2y > or = 4
6x + 4y < or = 36
2x + y < or = 10
x, y > or = 0
How would I go about graphing this on my calculator: 2x + 2y > or = 4. When I take out my ti-83 and try to input the equation 2x + 2y > or = 4 I can't seem to find how to put multiple variables into it and inout less than or equal to signs in there. I do realize how to do this pblem I just can't seem to grasp the idea of how to put it into a calculator. I would greatly appreciate all your help you can provide. Thanks.
You CAN'T graph an inequality on a calculator. You can, however, graph the equation 2x+ 2y= 4 (solve for y and enter it as y= 2- x) and that is the boundary between "> 4" and "< 4". Since you have 5 inequalities, your "feasible" region will be the five sided figure bounded by those 5 lines. I'm sure that you know that the minimal and maximal values of your linear target function will occur at one of the 5 vertices of that region.
Why use a calculator? Why not do it by hand? Don't be lazy! As HallsofIvy says, the 'feasible' region- the region that satisfies all inequalities- is the region bounded by all 5 lines. So plot the 5 lines by hand and find the bounded region. Then find all the points of intersection, see which point gives the lowest value for P= 30x + 10y- this will the minimisation of P, and the point that gives the highest value will be the maximum.
What, do it the "old fashioned way? How primitive!
Of course, if it easier to do it by hand than with a calculator...
You can, but you have to choose the shaded area for yourself. Much easier to do so manually.
