Linear Operator L with Zero Matrix Elements
4 replies · 2K views · last reply
sayebms
Suppose a linear operator L satisfies <A|L|A> = 0 for every state A. Show that then all matrix elements <B|L|A> = 0, and hence L = 0.
##<A|L|A>=L_{AA} and <B|L|A>=L_{BA}##
It seems very straight forward and I don't know how to prove it but here is what I have tried:
##<B|L|A> \to##Using resolution of Identity ##\to \sum_{A} <B|A><A|L|A> \to <B|L|A>=0##
Is it right or do I need to write more.
It is not correct, you are summing over A and at the same time assuming that ##|A\rangle## is a fixed state (i.e., the one you started with in ##\langle B|L|A\rangle##).
since the problems says for every state A so should I write as following ##<A_i|L|A_i>=0 \to ## then as before
## <B_j|L|A_i>=\sum_{i}<B_j|A_i><A_i|L|A_i>=0##
is it right now?
No, it is still wrong. You cannot let the state you are summing over in the completeness relation be denoted by the same as the state you have on the left-hand side. It is simply not correct.
should I solve it without the resolution of Identity?
