Linear tranformations equality
  • Thread starter Thread starter sphlanx
    Linear
The discussion centers on the equality of linear transformations based on their kernels and images. It is concluded that two linear transformations with the same kernel, specifically ker(f) = ker(g) = <0,0,0>, are not necessarily equal, as multiple transformations can share the same kernel but have different images. Conversely, it is argued that if the images of both transformations are the same, im(f) = im(g) = <0,0,0>, then they must be equal, as both represent the zero linear map. The participant expresses some uncertainty regarding the correctness of their conclusions but feels confident about the reasoning behind the image equality. Overall, the discussion highlights the nuances of linear transformation properties in relation to their kernels and images.
sphlanx
We are given a homogeneous system of 5 equations and 3 variables. We are asked to find the solutions (which i found to be unique and <0,0,0>) and then we are asked(along loads of other stuff:P):
a)If any two linear transformations g and f have kerf=kerg=<0,0,0> then they are equal.
b)If any two linear transformations g and f have imf=img=<0,0,0> then they are equal.
a) is wrong because there are infinite linear transformations with ker=<0,0,0> but different images. for (positive but not absolutely sure i am correct because the dimension of the images would be equal)
i think b) is correct but i am not sure. I would say that if imf=img=<0,0,0> then they are both the zero linear map so they are equal. Thanks again in advance
Sounds to me like you've got it down!
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
