Is T a Linear Transformation from R3 to R2?
zhfs
let T : R3 --> R2 be the transformation defined by T([x]) = [y+z]
y x+z
z
(a) show that T is a linear transformation
(b) calculate [T]B',B- the matrix of T with respect to the bases B and B' where
1 0 0
B = { [0] [1] [0] } and B' = {[1] [-1]}
0 0 1 1 1
(c) determine the coordinates of T{[1]} with respect to basis B'
nothing much can help...
part (a) is fine, can be proved
but have little problem in part (b)
since B is 3*3 matrix and B' is 2*2, i can't keep going on that
i've got [T]B={[0] [1][1]}
[1] [0][1]
and i can't keep going from here
and same as part (c) , how can i transfer a 3*1 into with respect 2*2
i don't know what's wrong with my typing
i tis not showing right
but B is standard basis for R3 100,010,001
and B' is [1 -1; 1 1]
Use LaTex! Web sites in general do not respect spaces.
The linear transformation, T, is given by
T\left(\begin{bmatrix}x \\ y \\ z\end{bmatrix}\right)= \begin{bmatrix} y+ z \\ x+ z\end{bmatrix}
(Click on the formula to see the code.)
To show that this is a linear transformation, you must show that T(u+ v)= T(u)+ T(v) for any u, v in R3 and that T(au)= aT(u) for any u in R3 and any real number a.
If T:U-> V and you are given bases for U and V, to write T as a matrix do this:
Apply T to each of the basis vector of U in turn. Write the result of each as a linear combination of the basis vector for V. The coefficients of each linear combination is a column in the matrix. For example
T\left(\begin{bmatrix}0 \\ 0 \\ 1\end{bmatrix}\right)= \begin{bmatrix}1 \\ 1\end{bmatrix}= 0\begin{bmatrix}1 \\ -1\end{bmatrix}+ 1\begin{bmatrix}1 \\ 1\end{bmatrix}
so the third column of the matrix is
\begin{bmatrix}0 \\ 1\end{bmatrix}
Note that the order in which the basis vectors are given is important. [0 0 1] is the third vector in the basis for R3 so applying T to it gives the third column of the matrix.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
