Linear Transformation of Matrix
10 replies · 3K views · last reply
h4v0k
Let A[itex]_{2x2}[/itex] have all entries=1 and let T: M[itex]_{2x2}[/itex][itex]\rightarrow[/itex]M[itex]_{2x2}[/itex] be the linear transformation defined by T(B)=AB for all B[itex]\in[/itex]M[itex]_{2x2}[/itex]
Find the matrix C=[T]s,s, where S is the standard basis for M[itex]_{2x2}[/itex]
My solution:
Standard basis for M[itex]_{2x2}[/itex]={(1,0),(0,1)}
T(1,0)=(1,1)
T(0,1)=(1,1)
[T]s,s=(1,1;1,1)
I'm not sure how correct this is. Any advice would be appreciated.
h4v0k said:
Still confused on this one
The standard basis for M_2x2 is four matrices [[1,0],[0,0]], [[0,1],[0,0]], [[0,0],[1,0]] and [[0,0],[0,1]]. You can express any other matrix as a linear sum of those. Now take a look at the problem again.
h4v0k said:
Doesn't this still produce the same vector?
What vector? What is A times the first basis matrix?
Sorry, the same matrix
A times first basis matrix is
[[1,0][0,0]]
then
[[0,0][1,0]], [[0,1][0,0]], and [[0,0][0,1]]
[[1,0][0,0]]
then
[[1,1],[1,1]]*[[1,0],[0,0]] isn't equal to [[1,0],[0,0]].
It appears it isn't
[[1,0][1,0]]
then
[[0,1][0,1]], [[1,0][1,0]], and [[0,1][0,1]]
h4v0k said:
It appears it isn't
[[1,0][1,0]]
then
Ok, so work on what the matrix C should be. It should be 4x4 since you have four basis elements.
h4v0k said:
Would this be
[[1,0,0,1],[1,0,0,1],[1,0,0,1],[1,0,0,1]]?
It would depend on which column represents which basis element. You should spell that out. But no I don't think that's it. How did you conclude that?
