Linearising Cosine: Taking Roots of Equation
  • Thread starter Thread starter Agrajag
    cosine
Agrajag
Linearise the following equation I(theta) = (I1 – I2 ) cos (2theta) + I2
where I1 and I2 are constants.
Not sure how to linearise the cos(2theta). Have tried trig identities, would the best option be to take roots of both sides of the equation?
Hi Agrajag, what do you mean by linearize? I usually understand "linearization" to mean: find the closest linear approximation to the given curve. This can be found by taking the derivative at a point to be the slope of a line that goes through that same point. This line is your linearization.
Hi friendbobbiny, the final equation should be in the form y=mx+c where y is I(theta) and x is theta.
In that case, my approach works! Have you read into finding a linearization by taking a derivative at some point of interest (or at any point of interest)?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
