Linking current-carrying wires to magnets
  • Thread starter Thread starter Cluelessness
    Magnets Wires
Current-carrying wires, such as solenoids, generate magnetic fields due to the movement of electric charges, similar to how magnets produce fields from the aligned spins of their electrons. The relationship between the two is primarily explained by Ampere's Law, which describes how electric currents create magnetic fields. While magnets have stable magnetic fields from electron alignment, they do not require a current like solenoids do. The discussion clarifies that the magnetic properties of materials stem from the synchronized movement of electrons rather than direct current flow. Understanding these principles helps bridge the concepts of magnetism and electric currents.
Cluelessness
This may be an obvious question but I have no idea:
How can anyone link current-carrying wires (solenoids) and its formulae, to magnets?!
All I've researched so far points out that magnets have their own stable magnetic field, attributed to the alignment of spins of the electrons of the atoms which the magnet is composed of. But is that all to it? Are there any other relationships, anything that I'm missing?
Welcome to PF!
Hi Cluelessness! Welcome to PF! :smile:
Basically, yes.
The only thing that causes magnetic fields is the movement of electric charge.
Even a charge moving with uniform velocity has a magnetic field.
Mechanically useful magnetic fields come from circular motion or spin of charges.
There's no essential difference between the tiny circular motion or spin of electrons in a magnet and the large-scale circular motion of electrons in a solenoid. :wink:
Thanks a lot tiny-tim! :D
Does that mean magnets exhibit magnetic properties solely due to synchronised movement of electrons i.e aligned domains? So this means that a current is not required like a solenoid? Or do aligned domains produce a current?
Sorry, I'm nearly there...I think :)
i'm really not familiar with magnetic domains, or magnetisable material generally :redface:
i think that if there was a current, it would be called a polarisation current, rather than something to do with magnetism :confused:
There is no link between electron spin, and the currents in a (air core) solenoidal coil producing a magnetic field. The magnetic field is due to Ampere's Law. http://en.wikipedia.org/wiki/Ampère's_circuital_law.
Electrons do have orbital and intrinsic spin dipole fields, which do impact magnetic materials and EPR (electron paramagnetic resonance).
The on-axis field in a solenoid is given in http://www.phys.uri.edu/~gerhard/PHY204/tsl215.pdf
Sorry for replying so late! ><
Thanks guys! I really appreciate it :D
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
