jbmolineux said:
Yes, I am aware that QM has a measurement problem. But historically the measurement problem combined with the positivist idea that "only the measurable is meaningful" to the actual belief that the unmeasurable is nonexistent, which a stop to inquiry, as the Weinberg article above spells out. I have heard that later the repudiation of "completeness" by Bell came to be accepted, but obviously decades of research-that-could've-been were lost by what were ultimately philosophical mistakes.
To be fair to the early quantum mechanicians, they did realize the problem and discussed it extensively. That is why we still have language like the "Heisenberg cut" and "von Neumann chain". Von Neumann's model of measurement is still one way of presenting the measurement problem that the reversible time evolution of the wave function alone does not produce definite experimental outcomes, contrary to experience. Von Neumann did make an error, but he could hardly have made the wrong claim if he had not been looking for a solution. Also, we know that not everyone accepted von Neumann's erroneous proof before Bell. Bohm, for example, produced a hidden variables theory that reproduces non-relativistic quantum mechanics. Also, Messiah's famous textbook does state that hidden variables that Einstein advocated was not excluded, and that he would adopt Copenhagen just because it was consistent with all experiments up to then.
The most common modern flavour of the Copenhagen interpretation does not deny a common-sense reality, but in fact explicitly states its existence, together with the idea that the wave function is a tool to describe that reality. I will follow the spirit of modern Copenhagen-style interpretations, such as Leifer and Spekkens, who say "the picture we have in mind is of the quantum state for a region representing beliefs about the physical state of the region, even though we do not yet have a model to propose for the underlying physical states."
jbmolineux said:
- Why is it impossible to know both the position and the velocity of a particle by the rebound of a photon hitting it?
It is impossible to know both the position and momentum of a quantum particle, because it does not and cannot have both position and momentum simultaneously. Quantum position and and quantum momentum refer to the results of different experimental procedures, and the procedures are such that you cannot perform both of them in the same place at the same time. We consider these procedures to measure "position" and "momentum", because the quantum "properties" reduce to the classical properties in the classical limit of quantum mechanics.
jbmolineux said:
- On Entanglement experiments - why can't the cause be explained by the same properties in each at the source? (I know I am out of my league with this question, and I believe the answer might be Bell's theorem itself...is that true?)
- Why couldn't there be an entanglement-type experiment where both particles were sent out "in the same way" so that you learn the information from one to know about the other? In other words, can you do something at the beginning to ensure that the position and velocity are the same, and then measure the position of one and the velocity of the other?
That is Bell's great achievement to show that if quantum mechanics is correct, the underlying reality cannot be explained by local properties, for some reasonable definition of "local".
jbmolineux said:
Yes, that was my understanding as well--although I've heard it both claimed that the Bell Test experiments vindicated "non-realism" and that it was simply LOCAL realism that they violated. But that leads me to another question--why is non-local realism so hard to fathom? What's so spooky about "action at a distance?" Didn't that die with gravity and electromagnetism? Don't those both clearly involve action-at-a-distance? (Or is it that they are not instantaneous but travel at the speed of light?)
It is considered "spooky" because Einstein liked to use colourful language. I'm not sure what Einstein had in mind, but it seems to be that spooky action of a distance is in conflict with a classical conception of special relativity, in which the action at a distance is instantaneous and faster than light.
At present, we know that quantum spooky action at a distance is not compatible with any local deterministic theory, but it does not allow faster than light communication, and is compatible with special relativity.
Are there models for the underlying reality compatible with quantum mechanics and relativity? That is still a matter of research. My personal view is that one promising area is to assume that relativity is not exact, for example in lattice models of quantum field theory. However, a problem with that approach is that at present we do not have a lattice model of chiral fermions interacting with nonabelian gauge bosons.
Two very good reviews of the measurement problem are (each is perhaps slightly biased in different ways, but I believe they have striven to be technically accurate):
http://arxiv.org/abs/quant-ph/0209123
Do we really understand quantum mechanics?
Franck Laloe
http://arxiv.org/abs/0712.0149
The Quantum Measurement Problem: State of Play
David Wallace
I should also mention the Transactional Interpretation, which I don't know enough about to know if it is technically right, but is interesting because it tries to use the retrocausation loophole in the Bell Tests.
