Solving Equations of the Form ln(x) = f(x)
The equation ln(x) = -x^2 + a*x + b requires numerical approximation methods for solutions. While the W-function might offer a theoretical approach, it is not straightforward. Recommended numerical methods include Brent's method and the cosecant method for effective solving. The consensus is that a direct analytical solution is not feasible. Numerical approximation is the best path forward for this type of equation.
nunchakula
Just came across this for a program I'm writing. I need to be able to solve an equation of the form ln(x) =f(x) where f isn't a logarithm. specifically, it's ln(x)=-x^2+ a*x+b.
Is this solvable for x or do I need a numeric approximation?
Mathematics news on Phys.org
Hello.
You must use a numerical approximation to solve this equation.
Bye.
It may be possible with the W-function, but I'd suggest numerical methods (Brent's method or the cosecant method).
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
